JUST PURCHASED LG LCD HDTV, SET IT UP TO CABLE BOX. UNABLE TO SET UP THE PANASONIC PT960 HOMETHEATRE SYSTEM TO CONNECT TO THE VIERA LINK SET UP MENU ON THE PANASONIC PT960
The first question you need to answer would be, "Does your TV support Viera Link?" Most newer Panasonic TVs and other A/V devices support it, but it's hit or miss (usually miss) with other brands. I know Onkyo is one brand that has stepped up and offered Viera Link support on some of its devices, but I'm not sure about others. If your LG brand TV doesn't support Viera Link, you are out of luck and you'll have to rely on seperate remotes for the TV and home theater. If your TV does support Viera Link, the next question would be, "Are you using HDMI to connect the devices?" Viera Link can only communicate over HDMI (not component video, S-video, coaxial, composite, digital optical audio, etc.) If either of the aforementioned questions were answered "no", you can still connect your devices and use them normally, but you won't get the benefit of Viera Link communication between the devices. In that case you will likely have to keep using separate remotes.
Can you explain a bit more please. What exactly is the problem? Are you getting any picture or audio through to the TV? Are you getting any picture or audio through to the home theatre? Have you got the home theatre setup via HDMI? Have you connected the audio from the cable to the home theatre via optical or phono? What model is your LG LCD HDTV?
I already have the manual in front of me for your home theatre system. If you can give me some more information I can help you out.
Thanks.
