To put back the metal wire ring on the door seal of your Zanussi washing machine, you can follow these steps:
Ensure safety: Before starting any repair work, make sure the washing machine is unplugged from the power source to avoid any accidents.
Locate the groove: Examine the door seal and locate the groove where the metal wire ring needs to be inserted. The wire ring typically fits into a groove on the inner edge of the seal.
Position the wire ring: Take the wire ring and position it in your hands so that it forms a complete circle. Make sure the ends of the wire are close together.
Start at the top: Begin by inserting one end of the wire ring into the groove at the top of the door seal. Apply gentle pressure and work your way around, pushing the wire into the groove.
Use your fingers or pliers: Depending on the size and tightness of the wire ring, you may be able to push it into the groove using your fingers. If it's difficult to do so, you can carefully use a pair of pliers to assist you. Be cautious not to damage the wire or the door seal during this process.
Continue around the seal: Slowly and steadily work your way around the door seal, pushing the wire ring into the groove. Take your time to ensure that the wire is securely in place and properly seated within the groove.
Double-check the installation: Once you've inserted the entire wire ring into the groove, double-check that it is evenly positioned and properly seated. Ensure that it's securely holding the door seal in place.
I'm Sophia and CEO of Homyclean, and I love sharing my amazing cleaning, laundry, bathroom,
best washing machine cleaners and maintenance experiences with you. I'll share hassle-free methods and top-notch products for washing and cleaning, fueling your passion for cleanliness.
By following these steps, you should be able to successfully put the metal wire ring back on the door seal of your Zanussi washing machine. If you encounter any difficulties or the wire ring doesn't fit properly, it's advisable to consult the manufacturer's manual or seek assistance from a professional technician.
how do i put on door seal for a tricity bendix aw 1100 s washing machine thanks
