This problem is intermittent. I can see the lamps come on but do not get the screen that shows channel selection (HDMI in my set up)- screen stays black. If I try to get at the set up menu it will not show up. Sometime if I unplug the power it will come back and run fine. Other times if I fiddle with the input selection long enough it will come back. Any ideas on what needs to be replaced and where to get the parts?
SOURCE: Samsung DLP HLN5065 intermittent shut off and color scrambled display
bad light engine assembly.......
SOURCE: BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
i have the exact same issue.
have you found the cause?
SOURCE: samsung tv turning off by itself
I have the same problem of the set turning off and on by itself. There is a circuit in Samsung TVs that would shut it down if a very loud noise occurs in the program being watched, but I have not noticed that correlation. My problem is solved by vacuuming the back panels of the set. They do not seem to have any significant dust on them, but I think the vacuum sucks somewhat inside of the TV and does some good with the fan that is supposed to be cooling the bulb and the mirror. It seems to work for months on end and when the problem recurrs, I vacuum again.
SOURCE: Samsung HL5067W power cycling
It's simple. Your TV does not like you. Perhaps you need to speak kindly to it before you force it to watch BBC for hours. Buy it a scone.
