SOURCE: service pack 2 installation problem(product key) for windows 2003
Try reentering the product key
Call microsoft and verify that your version is authentic and not pirated...
I had this problem already and it turned out althoug i had an authentic version the key i was sold with the cd was not recgoinised by microsoft. After providing my proof of purchase microsoft gave me a new key
SOURCE: how to create a bootable xp service pack 2 cd
To create bootable disk follow the steps: 1)Enter floppy disk or cd in your dvd/cd drive. 2)You can create boot disk by using Nero CD Burning software or other software with which you burn your cd or dvd. 3) to create with windows xp go to http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=FBE5E4FC-695F-43E5-AF05-719F45C382A4 Or carry out the following steps: Using Windows XP, place a blank floppy in drive A and format the disk. Navigate to the root folder of the system (in most cases this will be C:\) and copy the following files to the floppy disk. Boot.ini NTLDR Ntdetect.com If you can't see the files, click [Tools] and [Folder Options...] in the Menu Bar of Windows Explorer. Click the [View] tab and click the radio button next to [Show Hidden Files and Folders]. Remove the check mark next to [Hide Protected Operating System Files (Recommended)] then click [Apply] and [OK]. The files should now be visible in Windows Explorer. If the files still cannot be copied, right click each file, click [Properties] and remove the checkmark from the Read-Only attributes. Reset whatever attributes were unchecked after the copy procedure is completed. In addition to the files listed above, check the same directory for bootsect.dos and ntbootdd.sys files. If they are present on your system, copy them to the same floppy diskette. The disk is used as any other boot disk, inserting it into the floppy drive (A:\) and initiating a cold boot. Make sure the BIOS is set so that the A:\ drive is first in the boot sequence.
SOURCE: Update service pack 3 access is denied.
When you launch Windows Updates, don't choose the Express Updates but choose Custom. Then when you are presented with Service Pack 3, there is the option to not select it and then choose to continue to see what other updates there are. Personally, I do not recommend Automatic Updates or Express, always do it manually and always select Custom so an unwanted update doesn't get in under the radar and cause further problems. The rule of "if it isn't broken, don't fix it." really goes well with PC's.
SOURCE: I want to delete games from Windows XP
You can't delete them but you can disable them. Go to control panel. Click add/remove programs. Click Add/remove windows components from the left side. Games is under accessories.
