My problem is simple, the Player (T512) does not reconize any audio cd's at all it simply says "no disc" when they are inserted. DVD's load fine at first, the player reads them spins up, then spins back down and auto ejects the DVD, with the message "Disc Error". I opend up the player, and cleaned the lense, I started the player without it's cover and to me all mechanism's appear to function normal in the loading process. The only thing I've taken note of is that it seems that the player makes more noise the unsual when spinning up, a kinda humming sound that I dont think it has done prior to this problem. It should also be noted that this problem has increased from being a small problem where I had to reload the DVD/CD every 5th time or so.. to now .. where nothing will work at all. I have a feeling this is not something I can do anything about, but if anyone could confirm my worries, cheers Mort.
There is a strip that connects from the body of the lens to the circuit board take it off and replace it this will fix your problem you can contact dalbani in miami florida.to purchase the strip
Hai there. I've got exactly the same problem with my T512. Some addition problem on my player: it is very sensitive for copied cd's. While playing it makes some cracking noise. I need to admit the disc is slightly damaged. But on other cheaper players it plays fine.
I've got 2 more questions:
- "Iceshard" did you manage to fix the problem??
- Is it possible to upgrade the firmware of the player??
Thanks a lot !!!
Thanks a lot !!!
