Question about Samsung Galaxy Ace GT-S5830
How to do pattern unlock in samsung galaxy ace GT-S5830 when u forgot the pattern, n no options 4 gmail account
M trying 2 unlock it whit factory restore stuff but it is not coming at all
    New Friend:
I know my pattern lock.But six time use it wrong and now my phone is lock.. How i can open my pattern lock.. pls help me..
Posted on Apr 23, 2013
  • 226 Answers
If you select the Forgot pattern button you will have the option to enter the Gmail credential used to configure the phone. If that doesn't work do the following after removing and placing back the battery:
1. Press and hold the power and menu key for few second untill you enter the restore menu
2. After the menu show choose "wipe data/factory reset "
3a. Select yes and your phone will be restore to default
3b. After finish choose reboot now
4. It will restart. Don't panic because it take few minute until complete.
5. Don't panic just wait. If there is no response in 10 minute just release your battery and put it back again and repeat from first step.
Note;
-use menu key to select.
-use volume up down to choose the menu.
-make sure u have enough power in ur batttery.ake sure u have enough power in ur batttery.
Posted on Jun 11, 2012
  • 6 more comments
  • Vlad Mototolea
    Vlad Mototolea Apr 08, 2013
    glad to be of help my nepalese friend.
  • kaleem abdin khan May 04, 2013
    thanks for this solution very simple this work 100%
  • spvivekananda Sep 27, 2013
    Press and hold the power and menu key and volume up for few second untill you enter the restore menu 2. After the menu show choose "wipe data/factory reset " 3a. Select yes and your phone will be restore to default 3b. After finish choose reboot now 4. It will restart. Don't panic because it take few minute until complete. 5. Don't panic just wait. If there is no response in 10 minute just release your battery and put it back again and repeat from first step. Note; -use menu key to select. -use volume up down to choose the menu. -make sure u have enough power in ur batttery.ake sure u have enough power in ur batttery.SP vivekananda
  • janeshwor akoijam
    janeshwor akoijam Oct 25, 2013
    not working, plz tell me another option
  • janeshwor akoijam
    i have tried 3 4 time but it's not working why
  • janeshwor akoijam
    thanks u at last it's work. thnks u very much...
  • Emmanuel gThompson
    Emmanuel gThompson Jan 16, 2014
    emmanuel g. thompson thanks a million it work for me am very happy, hope that I and provide a solution one too.
  • zohaib banaras
    zohaib banaras Oct 13, 2014
    thanks a lot sir
    New Friend:
I have a galaxy ace my son has put to many pattens in and now it will not let me in its asking for my gmail password
i have reset the password and its still not letting me in
Posted on May 22, 2013
  • Ram Karan
    Ram Karan Nov 08, 2013
    "Swipe screen is locked gmail account failed i want to help pls"
  • jonytvi85
    jonytvi85 Jan 29, 2014
    user name faild
    New Friend:
I forget pettern code
Posted on Feb 12, 2013
    New Friend:
Patten has been lock and i dont know the true patten
Posted on Apr 25, 2013
    New Friend:
****Solved***** I had the same problem with my Captivate!! Problem: Too many pattern attempts: and my mail ID was not being validated Solution: I didnot wanted to do a software reset. So this is what worked out for me. Call to your mobile. Answer the call. During the call you should be able to pop up the settings menu. or you should be able to pull down notifications and other functions go to some applicationIt like wi-fii turn on wi fii then try to sing in again with correct google account. the you can create new patern. or Contacts,Memo and Noise Cancellation.Try one of Contacts or Memo. It took me 2 tries to get into contacts. On my first attempt it was showing the userid/Password screen again. Once in Contacts/memo you should be able to pull down notifications and other functions go to some application. I had a calendar notification, I went into it. Then click Home button which will show your home screen. Dont let your phone lock again which will make you go back to the square one!! **Important** you you have more than one accounts set up for sync. delete them all from sync and have just one account say one gmail account. I had a FB, Twitter and GMail accounts so this made me fail. Once you have a single account in "Accounts and Sync". Lock the screen with confidence and enter your account's ID and Password. This will unlock and bring your phone back to normal. It worked for me!! Hope it works for you too!! Let me know if it did!! Thanks.... Great Work guys Keep it up.!!
Posted on Apr 16, 2013
    New Friend:
I forget my pattan lock code
Posted on May 14, 2013
    New Friend:
Posted on Jun 20, 2013
  • Lekshmirajan Jun 20, 2013
    pls help my samsung galaxy Ace Gt-S5830i Swip screen locked pls help me google account faild
    New Friend:
I cant unlock patern lock of my samsung galaxy ace
Posted on Jul 26, 2013
    New Friend:
Thank you Vlad Mototolea, It works . I can save nearly 4 $ . It is great help to the suffer . I am from Nepal .....hard to manage it without money but today i am lucky ........
Posted on Apr 07, 2013
    New Friend:
Dear Sir!
i have done steps but my volume up and down buttons not working how do i select "wipe data/factory reset" this menu.
hope for response!
Posted on Sep 24, 2014
6ya staff
SOURCE:
Forgot my username and password for my samsung account on my galaxy s7 . I can't do anything on my phone. Can anyone help ? Its Sprint service if that helps .
Your username is your email address, how can you forget that? Do a Factory Reset and then set up a new account. Write the details down. However, read these links first.
  • How to find your Samsung Account ID and Password - YouTube www.youtube.com/watch?v=W9F7CS946zU
    • BY SAMSUNG CONTENT
    • 2 MIN
    • 939K VIEWS
    2014-09-18 · Video embedded · How to find your Samsung Account ID and Password ... Samsung Galaxy S3 Glas Wechseln Tauschen unter 20€ Reparieren ...
  • How to reset my Samsung Galaxy S7 to the factory default ... support.bell.ca > Bell Mobility This option lets you erase all of the content and settings on your Samsung Galaxy S7 and reset ... account password to ... How to reset my Samsung Galaxy S7 to ...
  • Forgot Password Samsung Galaxy Ace S5830 How To Hard Reset ... www.youtube.com/watch?v=Fy6pmlmTwP0
    • BY HARDRESETYOURPHONE
    • 2 MIN
    • 94K VIEWS
    2012-07-14 · Video embedded · Forgot Password Samsung Galaxy Ace S5830 How To Hard Reset ... Samsung Galaxy S7 vs iPhone 6S Water ... Samsung Galaxy Ace - Forgot Password - Hard Reset ...
  • I lost my samsung account password? - I forgot my username ... www.askmefast.com > Computers & Internet > Google > Account I lost my samsung account password? I forgot my username and passw ... I forgot my samsung account password on galaxy ace so please anybody help here ? ...
  • Remove an email account - Samsung Galaxy S7 - Sprint support.sprint.com > Support > Devices > Samsung Galaxy S7 32GB Remove an email account - Samsung Galaxy S7; ... Forgot my username. ... Forgot my username. Forgot my password. Sign up for My Sprint; Sign up for My Sprint;
  • What is my Samsung account username ... - Samsung Electronics www.samsung.com/us/support/account/.../faqs/usernames-passwords.html The email address you used when you created your Samsung account is used as your username ... > Profile > Forgot your ID or password?. Tap the Find ID tab, ...
  • http://www.bing.com/search?q=Forgot+my+username+and+password+for+my+samsung+account+on+my+galaxy+s7+&src=IE-SearchBox&FORM=IESR02&pc=EUPP_
    Jun 01, 2016 | Samsung Cell Phones
    My samsung galaxy y duos is locked after too many wrong patterns tried & now it is asking for gmail id & password. after putting that also it is not unlocking
    you could try your network provider for the puk code as they may have locked the phone because to many attempts made to get access
    May 12, 2013 | Samsung Galaxy Ace GT-S5830
    S5830 pattern attempts
    Hi if your forgotten your passcode/pattern, you can try restoring your phone by pressing Volume UP + HOME + POWER ON at the same time. Cheers
    May 07, 2013 | Samsung Galaxy Ace Gt-s5830i - Black...
    To unlock samsung galaxy ace gt-s5830
    To unlock SAMSUNG GALAXY ACE GT S5830 from Optus network lock you can use unlock code.There are many sources available to get unlock code.I would suggest the site Superunlockcodes.com here you can get unlock code at low cost and unlock from network lock .
    Nov 23, 2012 | Samsung Galaxy Ace S5830 GSM Cellphone...
    I forgot my google account on my samsung galaxy gt-s5360 that's why i cannot unlock it
    i cannot open samsung galaxy y GT s5360. i forgot my google account and passward
    Nov 06, 2012 | Samsung Galaxy Y GT-S5360 Factory Unlocked...
    Unlock free Samsung Galaxy Ace Gt-s5830
    You can't unlock a Samsung Galaxy ACE for free. But you can unlock a Samsung Galaxy Ace at affordable cost using unlock code. You can get the unlock code for your mobile from www.mobile-unlocker.com all the best mate.
    Jul 18, 2012 | Samsung Galaxy Ace Gt-s5830 - Purple...
    Galaxy ace GT-S5830
    Do not worry with the help of the codes you can unlock your samsung mobile because its safe for your mobile........
    Get the unlock code for your samsung Gt-S5830 model mobile from this site Wickedunlock.com , here it gives the easy methods to get the mobile unlocked.....
    May 07, 2012 | Samsung Galaxy Ace S5830 TF-2G Mobile...
    How to unlock samsung galaxy y (GT-S5360).to many pattern attemps
    I forget my unlock pattern code and now asking the gmail addres
    Oct 28, 2011 | Samsung Galaxy S GTI9000 Smartphone
    My samsung galaxy ace is pattern locked & i cant open my phone . i forgot my gmail account also
    My samsung galaxy ace2 18160 is pattern locked & i cant open my phone . i forgot my gmail account how to open my phone
    Mar 11, 2011 | Samsung Cell Phones
    Samsung Galaxy Ace GT-S5830 Logo
    9,604 people viewed this question
    Top Samsung Cameras Experts
    FIKRET UNALIR
    FIKRET UNALIR
    Level 1 Expert
    Anthony Ward
    Anthony Ward
    Are you a Samsung Camera Expert? Answer questions, earn points and help others
