Only XP drivers available for this laser printer. Is there still a proven way to connect this printer to a Windows 7 PC ?
SOURCE: where acn i get laser shot LBP-1120 Canon printer
download the driver from
http://software.canon-europe.com/products/0000524.asp
SOURCE: canon imageCLASS D320 printer driver for windows
Driver download link: Canon imageCLASS D320 Multifunction Printer Driver
SOURCE: i need a free canon fax-L28o driver download
The "official" printer driver for Canon Fax-L280, found on software-canon-europe (m1b9_frx.exe)
does not work on my PC with Windows XP.
The installation seems to be OK but no reaction when I ask for a print test... The files stands in the queue of the printer but no more !!!
SOURCE: canon laser shot lbp 1120 drivers wont work on windows 7
I just recently fixed the problem for my LBP-1120, so I thought I'd share to make life a little eaier (in case you are still experiencing the same problem).
Step 1: Uninstall any previous attempts to give you a clean slate to work with.
Step 2: Go to http://driverscollection.com/?H=LBP-1120&By=Canon
You want to download the CAPT Driver R1.10 V1.10
(It's 1.61Mb)
Direct Link: http://driverscollection.com/?file_cid=4185122914590a75abbdee86fed
Add the little cypher code, and click download.
Step 3: Run the file, it will extract to the same folder.
Step 4: Simply Start> Devices & Printers > Add Printer
Add Local Printer (I'm assuming USB001)
Have disk > Browse (Go to folder)
Alternatively, if your current Printer list shows "Canon Capt Printer" already, right click, go to Properties and try Updating the driver by using the folder/files you downloaded.
That should work now. Happy Printing! :-)
