SOURCE: Scanning into OCR using a Vista PC
Try using the WindowsXP driver directly, click on 'continue anyway' and see if that works.
Do you have more information or questions?
The more information you provide to us, the better we can help.
Thanks!
SOURCE: OCR problems for Brother MFC-8660DN with Vista 64bit
You are correct in that paperport 9 will not work on Vista and paperport 11 is the alternative. I called about a similar model and the guy at Brother told me that paperport 11 is included on an updated cd from brothermall.com for some models. It was only about $3 so you might want to check for your model. Hope this helps.
SOURCE: Hello, I need an OCR-Software for
There are free OCR programs on the Internet. Here are a few WEB sites -
http://www.freeocr.net/
http://www.makeuseof.com/tag/top-5-free-ocr-software-tools-to-convert-your-images-into-text-nb/
http://www.bitwisemag.com/2/Free-OCR-Program
http://www.simpleocr.com/
SOURCE: my brother mfc j220 canoot
It looks like the magenta print head nozzels are blocked.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
