Battery is fully charged and I have also inserted a SanDisk 8gb memory card. Still displaying "out of memory"
OK, FIRST OFF THE CARD YOU BOUGHT, IS IT COMPATIBLE WITH YOUR CAMERA? IT'S NOT AN SDHC, IS IT? ALSO, DID YOU FORMAT THE CARD? THESE ARE POSSIBLE REASONS YOUR CAMERA IS NOT RECOGNIZING THE 8GB MEMORY. IF YOU FORMATTED IT ON YOUR COMPUTER IT PROBABLY WON'T WORK IN YOUR CAMERA. YOU NEED TO FORMAT IT IN YOUR CAMERA TO HAVE IT BE RECOGNIZED. DOES YOUR CAMERA WORK WITH THE OLD CARD AND NOT SHOW THE ERROR? ARE YOU SURE YOU HAVE YOUR CAMERA SET TO USE THE SD CARD AND NOT INTERNAL MEMORY? CHECK THROUGH YOUR MENU ITEMS FOR CHOICES. TRY THESE FIRST AND IF YOU STILL NEED HELP, REPLY TO: ARCLIGHT1217. IF THIS IS HELPFUL, PLEASE RATE, THANKS!
