I'm having an audio/video sync problem when converting my Nikon D7000 h.264 video with a freeware and using in FCP 6. The video appears delayed 2 fps behind the audio after converting. Is there anyone recommend me a program which enables D7000 MOV workable in FCP 6.
MOV format with Prores codec is FCP 6preferred video. So a program which has prores codec output is greatly helpful.As far as I know, two apps can export Prores codec video. One is Clipwrap andanother is Video Converter released by Pavtube. Clipwrap can not achieve yourtask because it only supports AVCHD videos. So please test Pavtube VideoConverter to check if it is helpful. It provides free trial version in Pavtubesite.http://www.pavtube.com/video-converter-mac/
Nikon D7000 captures Full HD 1080p at 24fps with support for autofocus while filming, all full 1080p HD videos are recorded in MOV format, which is perfect for viewing but not supported by FCP X. As we all know, the ideal acceptable format for Final Cut Pro X is Apple ProRes 422 Codec(*.mov), so the best solution is to transcode our H.264 mov video clips to ProRes, which will simply make our footages editable and ready for Final Cut.
Here I'd like to recommend you to try Brorsoft Mac Video Converter for FCP X, which is the best H.264/MPEG-4 to ProRes Converter for D7000 Camera users to transcode Nikon D7000 recordings to Apple ProRes 422 for FCP X on Mac.
Source:H.264 to ProRes Conversion-Convert/Edit Nikon D7000 H.264 recordings to Final Cut Pro X( FCP X) on Mac
SOURCE: Audio problem with NIKON COOLPIX 2100
That's because this camera records video only without audio, same as on the 3100.
SOURCE: how to play lumix digital camera .mov to my dvd player
Hey! There are a lot of such conversion tools. I am now using this Wondershare DVD Converter Ultimate, which helps me convert various video format to any video/audio format I need(indcluding the format you have mentioned). And it also helps me burn dvd from video. It works well for me. You can also have a free trail of it. Hope that helps.
SOURCE: the .mov 720p videos made by the Canon sx20si can't be watched
If the files are not big, you can try http://www.zamzar.com/ and convert them to .Avi for playback over the net. Otherwise, try the Rad Videos Tools (Free of Charge), but this requires a working QuickTime install, and can be found here ...
http://www.radgametools.com/bnkdown.htm
SOURCE: I have a aiptek by mistake i format the sd card
You may need to try some photo recovery software to rescue the pictures, here are some for your option. You may not recover all the pictures, but will recover most of them.
Photo Recovery (for Windows)
Photo Recovery for Mac
Both programs are able to recover pictures, videos and music files.
Note: Before your files are recovered, do not attempt to save more files to the SD card in case the original lost files are overwritten.
Same problem, I hope anyone can give a clear hint on this. But my project
is urgent, I have no time to wait, just find a third party solution. I heard that I should convert D600 MOV to
ProRes 422 - the best codec for editing within FCP. My problem got
solved by following below guide, hope it helps you.
http://www.pavtube.com/guide/import-nikon-d600-video-to-fcp-fcpx.html
nikon d7000 r07
