Unplugged pj63 same affect
SOURCE: HI I have a 32xv515dg LCD-TV. It
This is a common problem an a failry easy DIY fix.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
SOURCE: 50hp95 just shut off and
Google your model and make and add "blink codes" to the end of it. The blinks are a self-diagnostic way of telling you what is wrong. After you find out what the blink code means, go from there. Most tvs do this when a pico fuse, capacitor or convergence IC has a problem.
