Iphone will not id caller even though on the phone's contact list
SOURCE: iphone doesnt recognise windows contacts list
Alot of times you have to call the company in order to get a special code that will help your iphone or ipod recognize windows on your computer. I had the same problem with my ipod shuffle, it wouldnt let me download songs to it until I called the number from the apple website for technical support. This should get you the help you need 1-800-MY-IPHONE (1-800-694-7466) and they should be able to give you a code for your computer to help it connect with your iphone.
SOURCE: why my caller id is not working,even though i saved their numbers
You may need to save the contacts to either your sim or phone which may help :)
SOURCE: Can't recognize caller's name when including country code
Easy. (hope not too late :))
1. Press green phone button (as making call, list of recent calls appears).
2. press "menu", go into "options", then go to "smart dialing".
3. Choose correct "country code" and "national number lenght".
4. save.
Good luck! (Pearl is the best phone ever, you just have to use some brains to make it usefull :) )
SOURCE: how can i back contact list from my 3g iphone
believe me , the best way to backup yr contacts to desktop is iDrive ... just intall it in yr iphone and follow the steps,, so simple
SOURCE: caller id doesn't work for iphone 4
Caller ID is a staple in every iPhone. Your service provider may have blocked your Caller ID, so make sure to check with them first. To check if your iPhone has enabled the Caller ID setting:
1. Go to settings.
2. Click on Phone.
3. Click on Show my Caller ID, and select Yes.
