Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis top-load washer won't fill with water, no power.
I replaced a timer last year and I took the new one apart and it looks good. I suspect the lid switch assembly is dead because I removed it and tried to activate it by hand and it would not work. Any further thoughts?
  • 869 Answers
Not the lid switch>>>The water level switch ...unless you have forgot to turn the water on,Please Rate This !!!!
Posted on Dec 02, 2008
6ya staff
SOURCE:
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
I have a maytag atlantis washer that will completely fill at the beginning of the cycle, stop, then make a very loud squeeling noise, stop, and now will not advance through any cycle...even manually. We...
The not completly filling and squeeling makes me want to look at the screen on the water valve that the hoses attach to on the rear of the machine for blockage preventing water flow,to me the squeeling is the solonoids on the water valve calling for water yet no water coming in. IF you manually fill the washer using buckets of water/a hose what will happen? perhaps try that!!
Also if you have the "aquaflow flood stop" hoses the internal stopper in the hose is bad,replace hoses using standard hoses
Good luck,i hope this helps you to fix your washer,
Gene
Aug 09, 2011 | Maytag Atlantis MAV9501E Top Load Washer
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top loading washer won't agate. Instead it fills with water and spins, then drains, fills for the rinse and spins. Thanks Bill
Open your control panel.
Disconnect then reconnect your timer wiring harness.
If this does not correct the problem,replace the timer.
Feb 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Dec 30, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Timer on maytag Atlantis
replace water inlet solenoid first if this doesnt work replace timer
Dec 08, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
218 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
