My tv is not working at all it only shows a lock and it is written factory and my friends were saying i should press display button but on my remote theres no display button what can i do?
I suspect that this has something to do with the channel lock, also known as parental control.
See the link below for the manual on how to check and change these settings. The parental control settings are on pages 15 - 25.
Whilst the manual doesn't specifically mention a lock icon being displayed, it seems logical.
Best of luck!
http://www.retrevo.com/support/Sharp-27N-S300-TVs-manual/id/276bh628/t/2/
SOURCE: my child lock my sharp
If you forget your password, please input *2398* to enter, then change to new PASSWORD . Good luck!
SOURCE: 2001 Sharp TV MODEL NUMBER 27N-S300
i have sharp tv.model ac/ca.my wife went bought me a innovage jumbo universal remote.it was missing the instructions and codes for this tv.can you help?thanks curt
SOURCE: Accessing Menu Sharp TV
I have a Sharp TV model 27F-S40 and also do not have the remote. I need to access the menu to change color, sound, etc.
Can I access the menu thru the channel or volume buttons on the face of the tv?
Bob
SOURCE: How to acess set-up menu without factory remote
The manual can be found near the bottom of the Product page for this TV.
From the manual, pg 11 -
If you misplaced your Remote Control you can still access most settings
via the MAIN MENU screen when you press both CH UP (8) and
DOWN (9) on the TV set.
• Some features of your TV Set will not be accessible without the Remote
Control. If you lost your Remote Control, contact a Sharp Authorized
Servicer by calling 1-800-BE-SHARP for a replacement.
Let us know if this fixes it for you.
Turn
on the TV and grab the remote. In most cases, you will need the original remote
to unlock the TV if you aren't sure of the unlock code. If you don't have the
original remote, you will need to purchase one.
Look
at the screen. If you see a blank screen with a red key on the bottom of the
screen, press 'Function' and 'Mute' at the same time. This should unlock the
channel. This is an option for people who want the TV to stay locked but, want
to be able to bypass the lock to watch a certain show or channel. All other
channels will remain locked and the TV will fully lock when it is turned off.
Unlock
all of the channels on the TV by entering the factory reset code. There are
three main reset codes that TV manufacturers set. These are 0711, 6688 and
3308. Try each one until you find the one that works. This will reset the TV to
original factory settings. When you do this, you will loose any information
that you have stored in the TV, such as favorite channels, automatic timers and
the clock. You will have to go through the full initial set up.
Call
the technical support service number in your owner's manual if none of those
codes work. A technician can help you troubleshoot the television because the
problem may not be the locking control. When you call, make sure that you have
the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Look at the screen. If you see a red key on the bottom of the screen,
press "Function" and "Mute" on the remote at the same time.
This will unlock the channel. Do this if you want to bypass the lock to watch a
certain show or channel while leaving the TV locked. All other channels will
remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by
entering 0711 or 3308. These are the Jensen factory reset codes that will reset
the TV to the original factory settings. By doing this, you will loose any
information that you have stored in the TV, such as channel labels and
schedules. You will have to program the TV again by going through the entire
initial set up.
•Call the technical support service number
in your owner's manual if neither of those codes work. A technician can help
you troubleshoot the television as the problem may not be the parental lock
feature. Have the model number and serial number of the TV available when you
call.
• Take your television to a TV repair shop if
neither of the codes work and the TV locked by itself while it was turned on.
In this case, the TV may need to be rewired.
initial set up.
call.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
One amoung the above process will surely unlock your RCA TV. OK.
