I have just come up against this issue my self, 4 x CM2320's installed on 150 PC's. After a lot of head scratching I dug out wire shark and did some network analysing as I thought it was a network issue. Turns out it sort of was, the HP software installs a custom network print port, this print port scans the network to see if the printer has changed its IP address BEFORE it tries to spool...!! The solution is to create a new network port and put the printer on that. Originally it took well over 90 seconds to print a test page, once the port was changed it dropped to 2...!!!! All PC's at this client were win XP so here's how to do it on an XP machine... Please note the printer should be on a static IP address!!!:
Start > Printers And Faxes > Right Click on the CM2320 PCL 6 printer > Properties > Ports >
If you scroll down to find the printer in the ports list you should find it has installed on a port called 'HP Colour LaserJet' or something similar.
Add Port > Select 'HP Standard TCP/IP Port' > New Port > Next > Type in the printers IP address ie 192.168.0.202 (Don't tick always print to this device) > Next > Standard - Dropdown - Hewlett Packard Jetdirect > Next > Finish.
The new port will now be in the ports list, click the tick box next to it > Apply > OK. Now try and print a test page, it should only take a second or two...!!!
SOURCE: hp laserjet 4350 printing slow down
Look on the left side of the tray. There should be 3 white fingers that stick out. Make sure they aren't broken or out of place. Also slide the paper size lever and make sure they work properly. There is also a custom and standard switch. Try to print out of the MP tray(fold down tray). If it prints normal speed, you probably have a problem with the tray.
SOURCE: Slow printing of Acrobat pdf files on HP Laserjet 1300
Hey look, sorry for all the BS you've been given. Its an issue here.
How much ram does your laser jet hold right now?
This would be the choke point on an HP laser jet.
A typical PDF file in high res can be many many megabytes in size and the HP Laser treats these documents as an image file, same in true in Windows, but uses local ram not printer ram like an Apple.
So, if you have a 256K chip, its possible, on your printer and the file is 4-6 MBs in size, you could be looking at a 16-20 minute print job.
I'm not familiar with any tricks to get your printer to use local ram as a cache. If you have Boot Camp, you might consider starting that emulator up and printing from that interface. No real hope for a difference but its worth the try.
Hope that give you some real thoughts to chew over.
Regards,
Worldvet
SOURCE: how to intalling network sanner HP LaserJet M1522nf MFP
If your printer is connected in the Network and you are able to print fine than there is no communication Error.
In htan case if you are not able to scan then you need to upgrade the firmware of the printer and install it and i m sure your printer wiill scan scanning on the Network.
Mentioned below is the link to download the latest firmware of the printer.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-70811-2
However before you start sending firmware to the printer you need to make sure that printer driver is installed on the PC.
Thanks and Regards
Neeraj Sharma
SOURCE: HP Laserjet 1200 prints pdf documents slow
pdf documents are historically slow, they usually depend on how they are created and how many attachments or upgrades have been added to the document. this accounts for some of the variations of speed the documents are printed.
NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
