Question about Coby Kyros MID70154G 7 Tablet Computer TTC8902 800 MHz 800 x 480 WVGA Display Android 21 HDMI
How do i fix non responsive, piece of ish, coby kyros mid7015 touchscreen without throwing it in the the dump
This thing was used maybe for 2 weeks, then i had it put away nice and safe, now touch screen is part of its past, short lived life.. help please, thing is sooo close to being thrown through a wall, or maybe even off a high building, or dropped into a active volcano dependig where i am at the time.
    New Friend:
Come on man....be patient, your kyros is a great stuff, all you have to do is just update to ICS 4.0.3. and you'll see a lightning speed in the operation and wifi conction.cheers get it done now.
Genn Sahipa
Posted on Apr 20, 2013
6ya staff
SOURCE:
Fred Flintstone
  • 76 Answers
SOURCE: my apps libaray on my
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase Everything" The following will occur: • The screen will display COBY • The screen will display Android • The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target. Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home". The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until: 1- You have configured your Wi-Fi 2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
Posted on Feb 28, 2011
Vlad Kuznetsov
  • 12 Answers
SOURCE: where can i get android 2.1 for my coby kyros
From what I've read, the tablet comes with Android 2.1 already installed on it. Try going to Settings->>About Tablet and making sure that Android version is 2.1.
darkslater
Alexander Rodriguez
  • 40 Answers
SOURCE: I CAN' T DOWNLOAD WITH
You will most likely need a driver so that your computer can recognize the device. Check the box that your Coby Kyros Tablet PC came in with and grab the Setup CD. It should have the driver inside the setup. If not you can download the driver (which may or may not be) at coby's official site show here
http://www.cobyusa.com/?p=prod&prod_num_id=10498&pcat_id=1013
Hope this helps : )
Posted on Dec 30, 2010
syed8rahman
  • 62 Answers
SOURCE: i need to download driver software for my coby
Try this link. It has solutions to errors and if you scroll down, driver downloads.
http://www.androidtablets.net/forum/coby-tablets/3217-kyros-mid-7015-7005-ultimate-guide-discussion-thread.html
Hope this helps!
Posted on Mar 20, 2011
Gale Todd
  • 1116 Answers
SOURCE: The screen in my Coby
You must contact Coby first. Here are the various ways to contact them:
Posted on Aug 30, 2011
How can I fix a froxen logo screen on a Kyros tablet?
you should give it to shop no other way. But the trick should work. press the button for 40 sec try it
May 19, 2015 | Coby Kyros Internet Touchscreen Tablet...
Download manual
Hope this is your model: http://www.manualslib.com/manual/254203/Coby-Kyros-Mid7015-4g.html
May 19, 2015 | Coby Kyros 7" Touchscreen Tablet
Stuck logo screen ipad
Probably frozen, you can try a hard reset. Just press both the power button (top-upper right) and home button (lower-front circle button) at the same time for about 10 seconds until it restarts. Post here again if this doesn't work, what was the last thing you did before this happened?
Oct 17, 2013 | Coby Kyros Internet Touchscreen Tablet...
Have a android tablet pc mid m729. wont charge up and wont come on. any suggestion
may be your charging port of tablet pc be faulty or gets dirt inside , go to any nearby electronic repair shops and get it repaired if u cant fix it on ur own.
Sep 20, 2013 | Coby Kyros Internet Touchscreen Tablet...
Tablet wont turn on
Please help me to get my MiTraveler 10C3 OS: Android 4.0 fixed.
Jun 12, 2013 | Coby Kyros Internet Touchscreen Tablet...
Mid m729 user guide
my tablet wont come on, all tat comes on is a thing that looks like a ice vream sandwich helppppppppppp please
Jan 01, 2013 | Coby Kyros Internet Touchscreen Tablet...
Manual for coby kyros MID7015
From the manufacturer's web site you may download the quick setup guide and the user manual.
Dec 16, 2011 | Coby Kyros MID7015 Tablet
Coby Kyros MID70154G 7 Tablet Computer TTC8902 800 MHz 800 x 480 WVGA Display Android 21 HDMI Logo
159 people viewed this question
Top Coby Tablets & eReaders Experts
 Mike M
Mike M
Marvin
Marvin
Lawrence Oravetz
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
