Can't figure out how to change ip address on scanner since we moved. I can see the old address, but won't allow access on copier to change.
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
SOURCE: access ip address inofmation page on aficio 3224c
Type the IP address of your machine into your web browser. Login to Administrator Mode as follows:
Username: admin (or possibly "administrator")
Password: (leave blank)
SOURCE: ricoh 2045e
The delivery server IP address is pushed to the machine from the scan router software. If it needs to be updated, you will have to remove and readd the I/O device within the scan router administration utility. If you do not use scan router you can set delivery option to off, and it will eliminate the error message.
SOURCE: How to Link Scanner from ricoh aficio 1232c
Download Twain Driver from ricoh site and you can use any softwere that suports twain scaning i use microsoft scan that comes with office 2003
SOURCE: Ricoh Aficio 1232c REFILL
You can't use any other brand of color toner to refill the AF1232, you'll have all kinds of issues. They do have compatible toners (generic) for that model but highly recommend OEM.
