SOURCE: My Sony KDL 52S5100 52 inch is great except for
Check the user manual. You have the Auto dark enabled.
Or so it sounds. Disable that.
Selvol
SOURCE: KDL-52S5100
More than likely the TV is in the "retail" mode which intentionally reverts to the "vivid" mode after a short period of time on the other settings, deemed best for retailer display puposes.
Follow the "return to factory settings" instructions found in the operators manual, pg 21 of KDL52S5100. Only the first half of the instructions are needed to put the TV in "home" mode, the 2nd slection to make after "language. After you have slected "home" I do not beleiev you need to any go further into the setup menu.
"Turn the TV on. Press and hold the "^" (up arrow) button on the remote and then push the "Power" button on the TV. Release the "up" arrow."
You should now be back to start, select langauge and home mode and then exit.
You now should be good to go and your picture mode selections should now stay put.
Sony has live tech help "chat" and I would suggest using them if this doesn't get it done - but I'm 99.95% sure this is your fix.
Testimonial: "Worked for me."
SOURCE: TV suddenly lost the ability to project red
Reset the colors setting back to factory original setting.Should have all colors back to original.Not than ur main tuner signal board is dead,must replaced.
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
SOURCE: There is no red in the picture.
yes,, call the company vendor,, they'll assist you,, sont let any local vendor operate your t.v,, trust only qualified personnal only
