Need the set up code for Sony Dvd progressive scan DVP-NS575P using ATT Uverse remote
SOURCE: Sony DVP NS575P will not play pc burnt DVD
John~ check formats with dvd player can be found in mannual - then burn dvd to suit mp3 or mp4 would normally work~ you can go to Realplayer.com to get tool to download on pc to this job. also try
Divx .com / utorret.com
or if you can get a Silvercrest dvd player this can also play pc dvd.in may different formats.
Phil
SOURCE: Unlock regional code for Sony DVP-NS575P
1) Turn your DVD off. 2) Use the remote control and press:
- Display
- Top Menu
- Clear
- Power
This should power the device into Service Mode.
3) Choose option 2 and then choose option 4.
4) There should be two fields: Input Code and Current Code, each one with 5 chars long.
Type: 12450
Then push zero on all the 5 places of the first and the second field.
Push ENTER.
5) There should be a zero on the device display, meaning that all regions are free.
6) Press POWER to turn it off and you're done.
Let me know if it works!
SOURCE: just need a remote control code for att uverse
First, there is no such thing as a 'universal' remote, even the 'learning' remotes will not learn from every original remote.
Second, for anyone to help you, you need to post both model numbers, the player's and the remotes.
Generally, if a remote is only even a little older than the player, it may not contain the code set for the player.
SOURCE: what is the att uverse remote code for Protron
hi,
Do you mean AT&T U-verse remote. then the code for protorn dvd plyaer is 2149
ok
sony dvp will only turn on using remote
