Whirlpool Duet front-load washer F02 usually means it is taking over 8
minutes for the washer to sense that the rinse or wash water has
drained, which either means that the drain/filter is clogged or the
pressure switch/tube is clogged (causing both the washer to over-fill
with water and not sensing that water has drained).
To clear out
the drain/filter, tilt the washer backwards a little for easier to the
kick-plate and support the front bottom with a wood block or similar,
remove the front kick-plate's (3) retaining screws and swing the
kick-plate up out of the way. The filter drain is behind the white knob
in the center, be prepared with something to catch any remaining water
and lots of towels to soak up any spills, and turn the knob
counter-clockwise to remove the filter.
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. The first three sites I've listed have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions about this repair, please post back and let me know. If the link does not take you directly to the instructions I provided, copy and paste the link to your web browser. I hope you find this information helpful.
HI There Here what you need on error codes. Drive
Motor Tachometer Error
The
control is unable to properly detect motor speed and the
machine will shut down. If a failure occurs during high-speed
spin, the door will be unlocked after 3 minutes.
Check
wire harness connections between the Drive Motor/Tachometer
and the Motor Control Unit (MCU), and between the MCU
and the Central Control Unit (CCU)
Check
the Drive Motor
Check
the MCU
Check
the Wire Harness
Hope this helps let me know. Thank you for writing to fix ya. Best regards Richard
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to Applianceaid.com where they have very good and complete trouble shooting and repair information on front loaders. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it.
F/06
Drive
The
Check
This is joyce
I just had to have my barrons replaced in my washer on the spin cycle it sounded like plane taking off. I dont know about yours but mine was loud, you probl. have the same problem. get a technician to come and check it out, all these machine's are hard to work on so let professional take care of it. if you need me to find someone in your area please just let me know.
thanks,
joyce
sounds like a faulty water inlet valve, not seating properly after closing the valve.replacing the valve is the only solution to this problem, in the meantime you can turn off your water supply in between doing loads.
