What is the error and how can it be fixed?
SOURCE: Ricoh 3800c error code SC555
This means the pressure roler thermistor is out of position or defective. Take out the fuser, the thermistor is a little pad that sits against the lower roller. Check that it is clean and that it is touching the roller, this fault is telling you that the press roller heat lamp stayed active for 100 seconds and the code is produced to prevent damage to the machine. I hope this helps.
has error code sc555
any help with this error would be greatly appreciated
