SOURCE: My Behringer Europower Pmp5000 Powered Mixer blew
Probably the channel A went. If you are fortunate, the power supply is still OK. There are protection circuits for the speakers, however you MUST use speakers that are rated at over 400 Watts. If you use smaller ones, they can get blown. There is a weakness primarily on insulation for channel A and an arc between layers of a circuit board can wipe out several transistors and a zener diode and sometimes a metering resistor. Once this happens, have unit serviced before using it again as further damage can result.
ALSO PLEASE read my tip I posted on FIXYA regarding a grounding hazard when using Speakon to 1/4 inch speaker cables... essentially the barrel of the 1/4 inch jack of the A channel is the hot lead, NOT the tip for that channel.
