Just got my first and new PS3. I am tryint to use the HDMI cable that is converted into L and R audio and video connection to tv. not getting anything from tv, from any of component options and or from video options. tried every possible way. i think. yes, everything is on, tv, cable , dvd, all work. but no ps3???? HELP ME PLEASE !!
SOURCE: hdmi receiver to hd plasma tv
1) I believe the "3 prong" you mean the RCA A/V cable. This cable is color coded red/white/Yellow (Right Audio/Left Audio/Video). This cable is OK for regular TV but when it come to HD, the quality of the picture fall short.
But you also could mean the 3 wires component cable that color coded Green/Blue/Red. If you plug only this without the Red/White for the speaker then you will only see the picture. This component cable help make the pic a lot clearer. But I believe not as good as DVI and HDMI. More info here http://en.wikipedia.org/wiki/List_of_display_interfaces
2) Most universal remote control come with a preset of keys to emulate other remotes. You need to search for the owner manual to figure out how and what code to put to use with a certain device.
Most new Universal remotes has a learning mode too that the user can "teach" the remote to emulate that "IR signal".
Now for the "HOW". It's a little complicated. But here is my 2cents. Most basic remotes has a light in front and this light is Infra Red light. So you don't see the light but it blinks. The blinking is the data of 1 and 0 that computer uses. Most of the time the remote is in sleep mode which uses very little power. One press of the button, it switch on the remote and carry out the performance of that button. The brain of the remote figure out which button was pressed and search in it's memory for the blinking pattern and blinks the light with that pattern and then fall back to sleep.
For the pattern itself, it contain informations. It usually start with the ID of the device that suppose to receive the signal. Follow is the "flag" and then the information of the button that was pressed. Then the final signal is basically say "End" to indicate that the message end. All device within range will get this information but if the ID don't belong to it, it will ignore the entire message.
Hope what I said helped. :D
SOURCE: HDMI Signal gone
The HDMI interface may have suffered a malfunction, this offten happens due to stray voltages on the ground plane. If you do not have electronics experience I would suggest taking the set to the shop and having it repaired
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
SOURCE: No video with HDMI port
try 2 things, first use the rgb cables or video (yellow) cable and plug it into the tv using one of the imports..(vid 1,2,3 etc...) and see if that works. then check to see if you get a picture by not using the cable box, by pass it and connect it connect it in the uhv channel. also make sure you have it on the right input of the tv (meaning scroll through the input button on your remote to find the picture...i've done this a million times). still no picture try your dvd player input and if you have a vhs input see if that works. if it is the hdmi input...to be honest it's expensive and a pain to replace...
SOURCE: HDMI stopped working tonight! I used an HDMI
The HDMI is a digital signal connector, in the tv is handled and decoded separately from the analogue connectors. Because of that the tolerances on the signal characteristics are much tighter so , if the chip is damaged even in the slightest way, it can no longer process the signal. The video from the Xbox is displayed because the signal generated there is most likely at the limits of the tolerances.
This is a hardware fault, that no reset will fix: the AV processor is faulty and the only way to fix that is to replace the motherboard.
