I am at the beach. did not drop the camera. it was working fine took 50 pics and then it had trouble focusing and then it just quit working. the lens is still out all i get is lens error and restart camera. I recharged the battery and looked for sand . It just beeps and nothing else. HELP!!!!!!
This is a delicate operation but you can try this: tap the camera lens up on a towel over a hard surface (counter top or floor) while you expect the lens to retract as in turning off. It may be enough jarring force to get cams back in the helix that moved the lens. Hit it hard and flat. IF that doesnt work, try tapping the lens down while it tries to retract. I have heard that people get so frustrated with it that they slam the camera lens up on a desk and that fixes it!
SOURCE: new camera - had trouble
Contact customer support at Canon. This should be covered with warranty.
SOURCE: lens will not retract. reading "lens error - restart"
The lens motor is burnt out. Has to be replaced.
SOURCE: lens error-restart camera on my canon power shot sd1000
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
SOURCE: Hello. I hae a
Unfortunately, this is a common problem on this model. Yet, no resolution other than getting it repaired.
There are a number of things you can try:
1. Ensure batteries are fully charged
2. Look carefully between the lens and the camera body for any sand or other dirt etc
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 2 minutes and refit
If
no luck then we have to try some things that could possibly result in
damaging your camera so should only be tried if happy to take that
risk...
5. Try thumping the camera into your other hand,
by thumping into your hand you are trying to jar the mechanism loose,
by using your hand you will hopefully not do it too hard or it will
hurt. You may need to do this a dozen or so times in different places to
work. I have found the flat of the camera bottom into the flat of your
hand best..
6. If the lens is stuck in the out position then
remove the batteries and try twisting the lens first one way then the
other, do not apply excessive force when doing this or you can break
gears, you are trying to reposition not force... Likewise if the lens
looks like it is crooked you can try pushing it back into position. This
has a higher chance of doing more harm than the thump so please be
careful...
7. Dismantle the camera, not for the faint hearted, you need to dismantle the lens assembly into the main body of the camera
If no luck then only other option is a serviceman I'm afraid, be sure to get a quotes as camera repairs can be uneconomical
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
If you need to get assistance having it serviced, the instructions at the web site below show how to unscrew and check it for loose cables.
https://www.ifixit.com/Guide/Canon+Power...
