When i try to play dragon ball raging blast 2 it says that it couldnt register the trophies and that the game will quit. i have tried many diffrent ways to fix it but so far nothing has worked
SOURCE: Registration of the trophy information could not
This is an issue with PSN since trophy's are an online issue. Wait till your able to log back in then try. PSN is down due to mantaince BTW they gave me an ETA of 9pm EST though it might be later.
SOURCE: PS3 Modern Warfare 2 error code
There is a worldwide issue with PSN at the moment:
We're aware that many of you are having problems connecting to PSN, and yes, we're looking into it. Stay tuned for updates. about 1 hours ago via web
SonyPlayStation;#';#';#'
SOURCE: how do i fix a ps3 error code 8001050f ??
There is a major problem right across the board at this very moment with the PSN Network, whereby some consoles are not synching properly and causing problems like you describe.
For a full breakdown please see this FixYa Tip.
If the solution helps, please leave a vote for it. Thanks.
SOURCE: i have been getting this error code on my ps3
ps3 8001050F happens when the PSN is under going updates and server maintence. It should pass in time, alot of people are having the same issue, which this happens once to twice a month. It will pass in a day proubly not even that much.
DrakeTech
Testimonial: "Thank you for your quick response. Very helpful because I'm not so worried about it now. Thanks!"
SOURCE: it keeps telling me registration
Reset Modem Run Internet Connection Test if that doesnt work try deleting Game Data Remove Save data to a USB drive and then delete that off of system Install game data Update game start game See if it runs fine then exit install save data restart game if error appears delete save data
