Laptop freezing after closing vlc player
Possible cause 1: System running out of memory
Possible cause 2: Wrong output setting
Possible cause 3: Corrupted files or hardware configuration error
You can check on this post to find more detailed reasons about this issue and check out some solutions for them:
Why Does VLC Freeze and How to Solve It?
My laptop is always goes hang after running any video file in VLC player. Pls reply what is the probable solution to run VLC player in Dell Latitude E5510?
SOURCE: my screen is turned sideways
The screen turned to the sidewards.. This issue can be fixed..
Try these steps
Press and hold the keys Control+ALT and then use the arrow keys and change the screen view.. The issue can be certainly fixed
SOURCE: How to Get a good Dell Latitude D520 Laptop
it sounds like you did the right thing, i would search google for "Dell D520 keyboard", you should find many places at different prices, if you havent bought from the site before, try reading some customer feedback, and also, the cheapest may not be the best, look for a good return policy and or warranty for the item. if this helps pleas give a fixya rating thanks
SOURCE: what is does the blue
9 in a lock light:
Turns on when the numeric keypad is enabled. Turn NumLk off by toggling the key.
You can change it in System Setup. Under Post Behavior heading.
Press to enter System Setup and make changes to user-definable settings. If you have trouble entering System Setup using this key, press when the keyboard lights first flash.
Use the checkbox to enable / disable the Num Lock LED when the system boots.
The factory default setting is Enabled.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: dell latitude e5510 web cam driver
hi
i have E5510 my webcam and mic is not working. please suggest me the driver for windows 7 32bits'
