A screw keeps coming loose on the frame and the frame keeps colapsing.
Hi If you're
in the UK
and the product is under 2 years old, please contact your retailer with your
proof of purchase and they can arrange for it to be sent to our engineers for
inspection / repair work required under warranty. If you're
outside the UK
please visit www.quinny.com and select the
country you're in, then use the "Contact Us" tab on the right side for your
enquiry to be sent through to the customer care team in your country. If you're
in the UK
you can order by contacting the customer care team on 01284 413 141 Mon-Thur
8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) If you're
outside the UK
please advise which country you're in and we can put you in touch with the correct
distribution team to assist you.
If you're in the UK and the product is over 2 years old or you no longer have
proof of purchase please contact the customer care team on 01284 413 141
Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) to discuss booking
it in for chargeable inspection / repair work required.
SOURCE: Folding up the Quinny Freestyle 4 Stroller
There is a little orange tab on the right hand side, lift this up and there are 2 pull up things on each side. you must pull up at same time with both.
SOURCE: pink quinny pram
start at the top and slide the 'cords' attached to the fabric off and away from the metal frame then do the sides and the same for the bottom, i know it is hard because you cant really see how it is attatched, but it is possible
SOURCE: Quinny Buzz Frame Problem
Try contacting them directly!
This may be a manufacturing problem that they are not aware of !
Click on the link below.Copy and Paste your problem into the email if you like.
http://www.quinny.com/quinny/forms/contact.aspx?mode=contact&language=nl-nl
Hope this is helpful.
Good Luck!
SOURCE: Folding - Quinny buzz 3
HI, if it's the same model as I have: start with the frame facing you with the break on, you will see 2 long grey 'buttons' situated where the seat clips in to the frame. One of these buttons has arrows on it like this ^, this one you push in the direction of the arrows. The other you, simultaneously push in. You then push the whole frame down - this takes a bit of pressure. The whole thing should fold flat, you then secure it with the cable located near the wheel.
This sounds very complicated, it isn't once you've done it the first time - I hope it makes sense to you!
SOURCE: I cant fold down my quinny speedi sx, i hold the
hi....i had the same problem but eventualu figured it out ...
put the footbrake on
remove the canopy
push the bar beside the hand brake and then firmly push the the pram downwards it should shut..
it is a bit tricky at first but u'll get it eventualy...
smaira
