THE MESSAGE E10 KEEPS APPEARING WHEN USING THE DRYER, THE WASHER IS WORKING AS NORMAL. THE DRYER WILL WORK FOR A FEW MINUTES AND THEN BEEPS AND DISPLAYS THE E10 MESSAGE.
E10 means theres no water going into the machine.Your machine has a triple water valve the 1 that feeds the dryer has proberly failed. Comes as a comp unit.
From Sears' site: Unplug the dryer for 5 minutes to reset the control board. Plug the dryer in and start a cycle. If the code appears, replace the electronic control board.
E10 means your machine has not filled to the correct water level (10 mins allowed) low water flow or blocked filter in the water valve . or faulty valve.check tap is turned on.
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets 1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems. 1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Washer dryers often have cold water valves with 3 separate solenoids. One for the main wash and rinses (which is clearly ok) and one for the condition rinse (to take the fabric conditioner down) which is probably ok too, and the 3rd one is for the dryer. It's possible this 3rd solenoid has failed.
Washer dryers need on a steady trickle of cold water running into the condenser chamber to convert the steam into water, which then gets pumped down the drain.
e10 means that there is a problem with the water supply. a condenser dryer needs cold water to operate properly. the e10 code will appear if: 1. the water is turned off 2.the water pressure is too low. 3.the solenoid valve is open circuit 4.there is a problem with the pressure switch (least likely)
Cold valve is at the end of blue inlet pipe remove lid and you will see it.
f E10 is only appearing when trying to dry, the problem almost certainly is the condenser valve solenoid open circuit. The green solenoid on the inlet valve. Should read about 4000 ohms.
My money would be on the solenoid coil being open circuit. The coil can be canabalised from most valves although you may have to modify the connections. For simpler repairs - contact Zanussi and get the entire triple inlet water valve to swap out.
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
