I have cleaned the water pump and i have replaced the ccu,but it will not move it only runs the timer fills,drains,but no spin. the tub does not move, i did get to see it go thru the spin cycle once even on high speed spin.now it will not work and after i have done all improvements mentioned above.does this washer have a motor control board that might be bad?? ...thanks
Duet washer service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Kenmore HE2 front load washer. All cycle lights flashing plus spin and clothes clean lights on.
I'm sure this is probably too late, but hopefully it will help some else. I just had the same problem. First, unplug the power. Then take the lower front panel off and grabbed a bucket. Place the bucket under the large "plug" on your right. This is the drain. Slowly unscrew the drain plug, Hold your nose as it will probably smell. Allow the water and such to drain into the bucket. When you see the blob of wet lint drop into the bucket you will know why the machine refused to work. Make sure you clean the drain plug and screw it back in tightly. Put the lower panel back on and reconnect the power. I hope this resolves your issue.
SOURCE: front load washer wont spin
yes. the solinoid or wax motor (depending on which switch you have) has fail and is not telling control that the door is locked. replacing the switch will fix it
SOURCE: Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
SOURCE: Kenmore hvy duty 90 series washer will not spin or drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
Also see the following for a more detailed description of how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission
"Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
SOURCE: My Kenmore HE2 Front load washer will not drain, displays F-33
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
This is an indication of a door latch failure and/or interconnecting wiring problem. The first step in troubleshooting the problem is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of your washing machine. Sometimes these error codes are erroneous and can be easily cleared by resetting the CCU. If the error code reappears following a CCU reset, then you have a genuine problem. In addition, if the door latch remains locked following this procedure, there is a manual release you can use to open the door. Follow these steps:
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with a 2 x 4, it makes access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
If you still have the error code displayed, inspect the door latch mechanism for any broken, loose, or missing components. Next, open the top panel of the washer by removing the three screws in the rear of the washer that hold the panel in place. With the screws removed, the panel will slide back, then off. Locate the door latch on the right hand side behind the front panel. Inspect the wiring harness from the door latch to the to CCU. The CCU is located directly behind the wash tub in the top rear of the washer. Make sure all the connectors are snug and not loose or broken. In the majority of cases, a persistent error is a failed door latch. If all these preliminary checks are unsuccessful, replace the door latch. Follow these steps:
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
NOTE: Another method is to access behind the front panel from the top with the top panel removed. Either method works, but I have found that going through the front offers better access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Hi CCU/Touchpad/LED assembly error (f21)
This error occurs if the touchpad/DED assembly is not able to transmit/receive data to/from the central control unit (CCU)
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding 2. Unplug washer or disconnect power for five minutes. This will reset the CCU, and may reactivate the communication if the damage isn't severing. 3. Check Wire Harness connectors to the touchpad/LED assembly and Central Control Unit (CCU).
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
