Washer works fine except for spin cycle doesn't do it EVERY time but almost every time doesn't matter the load (heavy or light) if I open it and rearrange clothes SOMETIMES it will do final spin without UL code and without jumping off the floor. I know its had coins get trapped under center piece and never retrieved but other than that you have to watch it to get through a complete cycle....?
SOURCE: UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust? The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles. Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around. Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load. That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
Hello Deanna Lytle - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
