My washing machine started squealing then stopped spinning,what do i do please ?
SOURCE: Squealing noise during spin cycle
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
SOURCE: Washing Machine Won't Spin/Drain
Apparently, there is an issue with this model. Get it checked out. I did.
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
The belt is slipping and needs replaced.
Squealing normal
belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
SOURCE: Not spinning
Sounds Like Its The Belt Open Up The Unit Get The Broken Belt And Take It To The Auto Parts Store And Have Them Give You One Of The Equal Length.
