SOURCE: i cannt find driver for monitor LG L1953S
Actually, you should be able to use the monitor without installing a driver. If it isn't recognized automatically, just set the resolution to 1280*1024 pixel and set the screen refresh rate to 60Hz:
In Windows XP right-click on the desktop, open the Properties dialog, select Settings and set the screen resolution. Click Advanced, select the Monitor tab and set the screen refresh rate. If the proper resolution was not available in the first dialog, uncheck "Hide modes that this monitor cannot display" and try again.
That being said, there is a "driver" package, also containing a color profile, available from LG here.
If this doesn't help, describe your problem in detail, let us know your operating system and which which monitor you are currently using.
