SOURCE: 2002 Ford Mustang convertible fuse box
go buy a cheap test light from a parts store they cost about ten bucks and you can test every single fuse quickly and easily by attaching the clip end to a bare metal surface in the car and touching the tip of the probe with the key on to either side of each fuse on the head of the fuse very quick and easy and you'll use it all the time please rate -jeff
SOURCE: 2000 Ford Mustang Convertible Slow Top Opening
My 2000 Mustang convertible has a noise and leaks fluid where could i go to fix it
SOURCE: Convertible Top Wont move but motor sounds.
If what you are trying does not fix your problem and the motor runs, then crack the line loose at each top cylinder, the cylinder is equipped with a check valve inside it that may be stuck, releive pressure and try again to operate, if possible check pressure at the pump.
SOURCE: mustang 2001 convertible top goes up but not down.
I've had a similar problem with my Mustang. What they did was replace the switch. I don't believe they come with 2 motors. But I would definitely check the wires and look for a loose wire that goes to the down relay. If you get a wiring diagram in the owner's manual, or even a repair manual, you should be able to find which wire.
SOURCE: convertible top won't go back up, can you help?
IT is probably a fuse. Does it work at all? my mustang had a busted cylinder and only 1 side would go up. If it doesnt work at all then check your fuses. With no manual you will have to use a flashlight and shine on them and see if one is blown. IF they all look good then I would go buy a testlight for about $10 and manually check the fuses for power. It oculd be the motor, however that will cost you several hundred dollars and that is if you install it yourself.
Testimonial: "Thank you so much. I have a friend checking fuses now, not sure. The top would still work to go down, but would give me a problem to go back up.THANKS"
