Purchased sony cdp ce500 5 disc changable player and need owner's manual.
SOURCE: instruction manual
Hi - You can download the manual from the link underlined in blue below:
cdp-ce375
Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: disc(s) jammed in sony 5-disc player--eject won't work
There are 6 or 7 phillips head screws that keep the top on; remove them and pop the top. This will give you access to all CD's. Remove them all, then plug the unit back in and press the open close button and check for normal operation. If it still wont open, it's broken a gear and needs to be serviced. You may consider replacement of the unit if inoperative, the replacement model is priced at $129.00 and a repair would probably cost the same if not more. If you need further help, post a comment and I can help you further.
SOURCE: Looking for user manual for a Sony model CDP-CX151
http://esupport.sony.com/US/perl/model-find.pl?mdl=CDP-CX151&PRODTYPE=33,32,63,71,7,102,26,80,72,44,55,27,74,84,57,61,103,89,10,35,78,48,77,29,50,39,64,58,12,41,81,52,60,73,66,101,45,76,86,62,54,67,70,68,17,2,1,88,100,82,25,28,83,59,69,49,24,104,53,79,42,22,46,13,6,85,36,3,51,9,47,38,4,34,37,43,5
SOURCE: I own a Sony 5
I'm sorry for the difficulties you're experiencing as the CD player is not working and displaying "NO DISC" message. Based on the information you have provided, it seems that the DVD lens head is not recognizing the discs. That cause the error message. It is required to contact a service center to replace the lens head. The model # you have provided is not correct. CDPCE500 is a new model and exchange is available from Sony.
Click hear to see the exchange option.
If you confirm that the model # is different, you may use the following link to get your nearest Service Center.
Repair
Thanks for understanding. Please let me know if you require any clarifications.
SOURCE: sony cdp-c910 Repeating
It needs a good cleaninmg and lube job, and if that don't work, it will need to be replaced.
