Some videos i try to play on it wont play on it ! it just say file format error.
Your player can play mp4 video. If you don't know how to convert video to mp4 video for your sylvania mp4 player smpk8000, this step by step guide will help you a lot.
http://www.reviewstown.com/how-to-convert-avi-mp4-wmv-mkv-flv-mpg-youtube-video.html
i got mini mp4 player but i dont knw what video format suppose 2 dis player
SOURCE: Video File Format Error
Here are instructions for how to put the videos on your v-touch.
http://www.visual-land.com/vtouchfaq.html
SOURCE: wont play video, i converted to avi using movavi
You will have to convert to mp4 format using converter
SOURCE: My touchmate 2GB Zeno MP4 player does not play videos
you must convert your video to format amv..
download amv converter,,you can find at google..
after finished converted,,your video can open with neno mp4 player..
googluck...
SOURCE: I cannot get any MP4
this happens cause it only supports MPeg 4 formats and do not plays any avi ...for that use the video converter and make all the videos in Mpeg format ...
another issue you should look for is the frame-rate and the bit-rate of the videos you convert ..
I will attach a video converter that will allow you to change these values on the files during the converting ..
remember ..add to the converter the video file...choose the exit file format Mpeg 4 ..and under the exit format values..modify the bit and frame -rates..
to know what values to use..download (copy into computer ) a sample file from the player that works..and analyze it by right click on the file and choose properties...at the advanced properties will show you the values of those..Use only those values for the exit format in conversion ..and after that transfer them into the player ...If they will be similar with the sample it wil be playable ..
here is a converter that will allow you to change the values..
http://www.any-video-converter.com/products/for_video_free/
Hii,
You may not be
able to play your video due to any type of damage to file. So in
order to repair unplayable mp4 you need to
have Repair mp4 which easily regenerates a new mp4 file. Any user may get it
over internet for evaluation purpose.
