Since DirecTV changed their guide to HD, the banner appears slightly out of the screen. When I asked them, they said that I needed to zoom in the TV. Any thoughts on how to do it? Thanks
SOURCE: Describe your Mitsubishi WS-65313 65 in.... Problem:
look for the CONVERGENCE settings either behind a small panel on the front or through the menu with the remote control
Connect your component cables to the DTV connections.
SOURCE: Image problem with WS-65809 65" Mitsubishi Projection TV
WS-65809?, if convergence is skewed and comes and goes, uses two of the STK-392-570 CONVERGENCE IC chips.
I
have seen a lot of the Mitsubishi sets that use these two chips where
the convergence jumps in and out. You need to replace both chips and
adjust the set.
You can buy a pair of the chips on EBAY for less than 13 dollars plus shipping.
I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THE SETS THAT USE THESE TWO CHIPS.
If
you or someone you know can do the repair you can save the set and a
lot of money--most shops are going to get at least 300 for this kind of
repair--I know as I have done hundreds of them here.
The
instructions tell you everything you will need and how to do the
repair. I have helped many people here do this based on my instructions.
If you want the instructions let me know and I will either post them here or send them to you.
If this information has helped you, rate this solution as I do this here for FREE.
SD TECH
SOURCE: Mitsubishi TV Model #WS65903 - Green Shadow Lines on Screen
Something is not right here--The green is adjustable in the TECH menu--did this person adjust or try to adjust in the customer or the TECH menu?
If you confirm actual model number I can tell you how to get into the TECH menu--yes--green will not adjust in customer menu--it determines geometry and is only adjusted in the TECH menu.
Also, this set requires any convergence adjustments to be done in 480 and then in 1080--if only adjusted in one mode the other will still be bad.
Let me know if you know how to adjust in TECH menu or not--with exact model number I can tell you how to get there.
If this helps you rate this solution as I do this here for free.
SD TECH
Testimonial: "I appreciate the detailed response. I will try your suggestion and let you know how it works. Take care."
The power supply will need to be replaced.
