Husqvarna 130bt 130 Bt Gas Powered Backpack Leaf Blower 29.5cc Reb Logo
Posted on Dec 08, 2017
Handle assembly I recently ran over the handle of Husqvarna 130 BT Backpack blower. I reordered all the necessary parts however I cannot figure out how to align all the parts in the correct spot. A diagram of the inside of the blower handle would be great but I cannot seem to find one online anywhere. Any help would be great. Thanks!
5 Related Answers
Anonymous
  • 163 Answers
  • Posted on Nov 30, 2008
SOURCE: leafblower
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Anonymous
  • 251 Answers
  • Posted on Oct 21, 2009
SOURCE: husqvarna 125bt backpack leaf blower. I put
if you've ran it for any length of time you will need a new cylinder and piston/rings and cylinder gasket ,
take the muffler off and look for scoring /scorching on the piston
Jeff Hagemann
  • 430 Answers
  • Posted on Nov 26, 2009
SOURCE: Husqvarna 155bt Gas Backpack Leaf Blower throttle
Do you mean the throttle lock? It is a basic mechanical lock. If it just spins I would assume that a chunk of plastic has broke off or the lever is misplaced. Take the throttle housing apart and identify the problem. New parts are available from your local Husqvarna dealer.
Jeff Hagemann
  • 430 Answers
  • Posted on Dec 01, 2009
SOURCE: Husqvarna backpack blower 40 B stalls when going
The unit is running like that because of a lean condition. Depending on the situation it can be solved by adjustment ( Im thinking your particular unit may not have any adjustment) , rebuilding the carb ( carb kits are $15-20 from your local Husqvarna dealer), and/or replacing the fuel lines.
Testimonial: "Thanks. I'm thinking the carb needs rebuilding and fuel lines could be an issue. In checking some prices with Husqvarna 60 to 70 bucks to rebuild."
Anonymous
  • 10865 Answers
  • Posted on Feb 04, 2010
SOURCE: husqvarna 356 backpack blower,when it gets hot it
Hello. You may have a partially gummed up carburator. Get a bottle of SEAFOAM at the auto parts store. follow the directions about how much to add and add it to your fuel. Run a couple of tanks of this enhanced fuel through your blower and it should be aok. Regards, Joe
ps - kindly rate my answer. thankyou.
What is the oil mix for 2 gallons of gas for a 2 cycle gas leaf blower
Only use 50 to 1 as that is what is specified.
To get 50 to one ratio with the 6.4 oz bottle of 2 stroke oil just add 2 1/2 U.S.. gallons and that will be 50 to 1 ratio so you will have the correct ratio .
Put gas only in motor
Did you run it with the pure gas in the tank? If so, it's probably beyond repair of the average homeowner. If you did not run it put your mixed fuel in the tank, push the primer many times to force the oil/gas mix into the carb, and you should be good.
Worked last weekend will not start
Need more info. Is it getting gas? You can check this by squirting some fuel into the carb or spark plug hole and cranking it. If it tries to go, then it is getting gas. (Be sure to put the plug back in though). We can work from there. . .
It won't start
How long has the gas been in the Blower?
If it was 10% Ethanol gas( lie most States sell at the gas pump) and it has been in the Blower for more than a few months, you probably have carburetor issues.
Husqvarna Repair Manual
Have you used the correct fuel and oil mixture.?
If its new and still under warranty then take it back to your local dealer.
Here's the parts manual
4helpful
HUSQVARNA 130BT GAS BLOWER STARTS FINE, BUT LOSES POWER WHEN I TRY TO USE????
Sounds like a fuel starvation problem, Strip and clean carb. Avoid using airlines to clean carbs. remove low and high adjustment screws, reset to factory settings. Walbro carbs are generally scew both of them back in all the way and then turn out 2 full turns each anticlockwise.
What is part number for plastic choke clip on husqvarna 356 bt blower
The clip is part of the choke shaft, the choke pull wire clips into it, the part no. is 537390201 they always break, the blue choke pull itself is part no. 537215701.
4helpful
Husqvarna 125bt backpack leaf blower. I put
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
