The screen is split perfectly down the middle. Right side has perfect picture while left side looks like a multi-colored tight weave carpet.
SOURCE: Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
SOURCE: Samsung DLP HL-P5674W Screen is stretched at the top and bottom...
did you ever find out the problem , mine is doing the same thing,
please email [email protected] if you can help
thank you so much
debi
SOURCE: Model LN32B360C5DX2A My screen seems to
Your TV suffers from horizontal phase shift. It may be due to the Ic fault or horizontal output sync: signal from the LOT not reaches to the respective pin of that Ic. Check first whether the horizontal sync: signal from one pin of the LOT reaches to the sync: pin of the Ic. If you have a frequency meter the thing should be easy.
Most common is IC fault.
