Panasonic Toughbook CF-51 Notebook Logo
Michele Trull Posted on Jun 20, 2012
Need a motherboard for a Panasonic CF-51 MK3 series laptop. Original Part number is no longer available DL3UP1493BAA, are there any other versions of this motherboard that will work as a replacement?
5 Related Answers
Anonymous
  • Posted on Nov 25, 2008
SOURCE: Toughbook CF-51 Sound
You can download the XP drivers from the panasonic site. CF-51 got many flavors and be sure that your model numbers are at hand when you retrieve the factory installed drivers.
Delete all SigmaTel drivers from the registry hardware section. This would help reinstall the correct driver. The presence of these wrong registry values prevent successful installation of the factory drivers.
I have installed se7en, vista and XP successfully. The sound is really problematic since Dell and Gateway laptops use similar sound chips and offers drivers on the net... but they don't work at all. The Gateway driver seems to install perfectly from device manager report, but only the mic works & no sound.
What I do is install the factory provided drivers in XP compatible mode and then use windows update to download the latest SigmaTel drivers (se7en pre-beta). Windows got a more compatible driver but it can only install over the original since the chips cannot be recognized.
Anonymous
  • Posted on Dec 25, 2008
SOURCE: Panasonic CF-51 Toughbook Fn keys don't work at all
The following website contains the needed drivers:
https://eww.pavc.panasonic.co.jp/pc/cgi-bin/itn/toughbook/dl01.cgi
Select your model of CF-51 Toughbook, but you MUST be specific. There are about nine variations of the CF-51 so you must use the right drivers.
Download the hkeyapp, hkeyset, and hotkey files and unpack all files. Use the default unpack locations. If you download the files for a laptop version that is not your own, when you try to run any of these files the computer will tell you that the file is not for your model. If the files successfully unpack then you know you have the right files.
For hkeyset and hkeyapp you must run the set-up applications in the unpacked folders.
Go to Control Panel>System>Hardware>Device Manager and go to Other Devices.
The Hotkeys will appear as an "Unknown Devices" so if there is more than one, right click and choose "Update Driver".
Select "Install driver from specific location" and direct it to "C:\util2\drivers\hotkey" folder.
The computer will find the file and install the driver after which point you must restart the computer.
Hope this helps. It took me a while to figure this stuff out on my own so hope it speeds up somebody else's attempt.
Andrew
Anonymous
  • Posted on Nov 19, 2009
SOURCE: Panasonic CF-51,s are becoming common on Ebay but
I found this via pendrivelinux.com:
http://www.pendrivelinux.com/testing-your-system-for-usb-boot-compatibility/
So try that out. I just got a toughbook cf-51 and will try it soon myself. Mine came with an XP reg code so maybe that can run from a virtual machine inside of linux.
My advice is to resist the urge to drop yours onto cement from a couple of feet. Not quite that tough.
The hard drive caddy is "the catch", for certain.
Too lazy to look into what the hdd connector is for that, maybe there's a cable or converter somewhere.
AV
Anonymous
  • 2600 Answers
  • Posted on Jun 21, 2010
SOURCE: how to remove wireless card from panasonic cf-51?
The mini pci card or wireless is under the small access door on the bottom of the laptop. It is accessed with one screw holding the access door in place.
Anonymous
  • 71 Answers
  • Posted on Feb 19, 2011
SOURCE: Installed Windows 7 on Panasonic Toughbook CF-51
..install an audio driver, it is found on the DVD package..
1helpful
2answers
Where do I find a restore and recovery cd for a panasonic toughbook cf-51 mk2LL?
I wouldn't suggest buying such recovery CDs from 3rd parties when you have the option to get it from Original manufacturer. Buying it from a third party will not guarantee desired results and you may lose a lot of money. You can get it through the official Panasonic website. Here's the link:
Panasonic Mobile Computing DVD Requests
2answers
Remove bios password for a panasonic toughbook cf-30k
  • Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
  • 0helpful
    Cf 51 model number doesn't match any of their numbers
    toughbook drivers go with cpu such as Pentium 4. Ebay people sells driver disk.
    Irql not less or equal blue sreen cf-51
    reformatting the disk / restore computer back to company settings...is only the resolution for this...
    To reinstall your operating system, you must have a CD drive in your multimedia pocket.
    Note: CF-51 (Mk2) and CF-51 (Mk3) can also boot to an external Panasonic USB CD drive.
    When the laptop is first powered on, the Panasonic name appears in white lettering with the phrase 'Press F2 to enter Setup' directly below it. When this phrase appears on the screen, immediately press F2 on your keyboard. Put the Panasonic recovery CD in your drive and use the arrow keys to move to the boot tab. Change the order of boot so the CD drive boots first. To do this, highlight the CD drive and press F6 until CD drive is the No. 1 listing. Press F10 to save your changes, exit and follow the instructions when your CD starts running.
    1helpful
    Panasonic CF 51 keeps shutting down
    At what point does it shut down? Normally thats caused by heat and/or could be viruses. I would blow out all the ports with compressed air. Does it get into windows before it shuts down?
    Need a motherboard for a cf 51. mine is a dl3up1481aaa. That number cannot be found. will anyother work in it's place.
    There's one on ebay right now ! check it out fast.
    http://cgi.ebay.com/Panasonic-Toughbook-CF-51-Motherboard-DL3UP1379AAA_W0QQitemZ360164329640QQcmdZViewItemQQimsxZ20090621?IMSfp=TL090621142002r28025
    Locate battery
    Actually thr bios battery is on the motherboard ..u have to open the laptop and look for it..
    2answers
    Battery discharges too quickly
    Time for a new battery. They don't last forever.
    Top Panasonic Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
