The part is a "ribbon cable" for an lcd monitor...ribbon
made by Youngshin (AWM 2896 30V 80C VW-1).
2 ribbon cables for a hp
pavilion f1503 LCD monitor (the two from the AD board to the TCP)
The
LCD panel is made by HannStar (HSD150SX84).
Also, looking for other LCD
parts, particularly:
the AD board for a Proview Pro-576 (I assume Sylvania
PL-576 & Mag LT576s are similar); Board #: 200-100-AS576 Rev: B MV5-S2?
It uses a sampo inverter (QPWBGL8621DG) & a AU Optronics M150XN05 LCD.
SOURCE: HP Pavilion F1503 LCD Monitor
If you can see the backlight ,white 2pin connectors connect to invertor pCB.Look around these two connectors you should see 2 brown/yellow/red transformers with a ferrite core.These are the inverter transformers , resolder all pins and power transistors around it.
That should solve your proble.
Please provide feedback and rate this solution.
Samir.
SOURCE: inverter problem
1800652667 as soon as hurricane Ike gets done with Houston, Texas. Or www.hp.com/go/support
