Do you do a replacement bolt set for the quinny buzz 3?
Hi
Yes replacement bolts are available. If you're in the UK please contact customer care on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
If you're not in the UK please go to www.quinny.com and select the country you're in, then use the "Contact Us" tab on the right side of the page to get in touch with the customer care team for your country.
SOURCE: I need front replacement wheels for quinny buzz 3
If you are in the UK, the following website is much cheaper than the others listed...
https://www.lesters-nurseryworld.co.uk
SOURCE: spare tyre/wheel
You don't need a whole wheel, inner tubes are available at most cycle shops - it is the same size as used on the small bikes for kids (12 1/2 x 1.75 x 2 1/4) - they cost around £4.50 and if you're not sure how to fit it, then they could probably do that as well.
SOURCE: Spare back wheel and inner tube needed for Quinny
You can buy spare parts from www.buggypitstop.co.uk
SOURCE: quinny buzz 3 and front wheel
I would personally recommend the Buzz 4 front wheel as I beleive that this offers much more stability than a single front wheel. If this does not work out for you, you can always eBay it, it will sell within minutes!
Hope this helps.
SOURCE: where can i get spares for my quinny buzz ive
Depends on where you are located. If your are in Australia, Karlisles Pram Fix can supply spare parts for the Quinny models and do repairs, there details can be found at www.karlisles.com.a
As for other countries, Quinny has authosied suppliers and repairs around the world, check there website for details.
Hope that helps
