Question about Maytag Neptune MAH9500A Front Load Washer
I am getting code nd on my maytag neptune washer. how can i fix?
  • 254 Answers
ND code is "no drain" the washer probably has a drain plug/filter on the main pump, more than likely all you need to do is clear debris from the pump.
Posted on Jun 20, 2012
6ya staff
SOURCE:
Anonymous
SOURCE: maytag neptune washer code nd,
nd means not draining. u may to check the plastic drain pipe in back to back sure it doesnt have a kink in it, and that it is placed so that the pump inside the washing machine doesn't have to pump it too far to get to the drain.
Posted on Sep 29, 2008
Anonymous
SOURCE: Maytag Neptune Error COde "nd"
I had the exact same problem. nd code (no-drain) at the end of the cycle and when I opened the door the machine was still full of water. I took the back panel off the washer and disconnected the drain hose from the pump. (You're going to get quite a bit of water gushing out at you so be prepared with towels or a shop vac.) At this point you should see a little rubber disc over the end of the section you just exposed on the pump. This is a little drain flap. Just lift it up and you should be able to see into the pump a little bit. At this point I poked around in there with my finger and found a hair pin stuck in the pump! I wasn't able to get it out from this end of the pump so I disconnected the big rubber boot which connects the wash drum to the pump. Then I was able to twist the pump (counter clock-wise) and release it from the washer base. I didn't have to disconnect any wires and was then able to see into the other side of the pump and pull the hairpin out. Put everything back together and it's worked fine ever since. I've never even looked inside a washing machine before but it really was really fairly simple. Now my husband really does think I'm a domestic Goddess. I said he should take me out to dinner with the money we saved on a service call!!
Posted on Mar 18, 2009
Anonymous
  • 373 Answers
SOURCE: What does the code ND mean?
ND - No Drain
Machine control board monitors water level in washer during and at the end of pump out. If wash level does not reset pressure switch, it will see water left in the washer.
1.Check for pump/drain restriction.
2.Check pump operation.
3.Check pressure switch for open contacts.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
Posted on Apr 10, 2009
Anonymous
This is now the 3rd time this has happened. The 1st 2 times it cost me ~$100 to have a technician come in and fix.
This time, I did it easily. For my Maytag Neptune washer, I removed the back panel (2 screws). On the bottom tray is the water discharge pump. On the output side of the pump there is a small cavity under the rubber flapper where a nickle fits perfectly. I removed the nickle, reattached the output drain line. started it up ...
and viola! the problem solved.
Posted on Jun 28, 2009
canbruce75
Bruce Canfield
  • 1776 Answers
SOURCE: maytag neptune frontload washer code nd
Yes maam, I sympathize with the situation. The "nd" code on the Neptune is usually a pump related issue. Check the drain line for kinks first, and then the pump will have to be checked. No matter how diligent we are, inevitably hard objects like pins, coins, etc., make it into the washer. Remove the hoses from the pump and using a flashlight, look into the suction port and check for any obstructions. Also check the pump impeller for any broken/missing blades and ensure that the impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hard objects that make it to the pump can damage the impeller blades on the pump. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Aug 27, 2009
Testimonial: "canbruce75 was extremely helpful. His directions helped know where to look for my issues. Thanks so much!!!!"
My Maytag Neptune washer has "np" flashing. The door is locked and the cycle is not complete
Are you sure this is not an nd and not an np flash code? If so then the code stands for no drain, likely something is clogging the washer pump inlet.
Aug 20, 2016 | Maytag Neptune Washing Machines
I am getting the nd error
you can get help in this matter at appliancerepairplanet.vstore.ca and you can get a sevice manual and help in this matter
Dec 15, 2010 | Maytag Neptune MAH6700A Front Load Washer
Maytag neptune mah9700aww error code nd
Remove water pump, check for thongs, baby socks and sometimes hair pins or even screws can obstruct the water pump.
Simply remove the pump and remove the obstruction that is keeping it from draining.
This will fix your problem.
Apr 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
I keep getting the error code nd on my Maytag neptune whats this mean?
Error ND means that there is a drain problem.
Either there is debris inside drain pump hose, or the pump itself is faulty.
The problem is fixed accessing the drain pump hose to check for a blockage.
Keep a container ready to collect water when you undo pump hose.
Parts and diagrams available here.
Nov 14, 2009 | Maytag Neptune MAH9700 Front Load Washer
How do i fix nd code for mde5500ayw maytag neptune
There are two possible causes to the "nd" code. The first is with the pump itself. Either is is blocked or it is simply worn out and needs replacing. The second is a malfunction with the control board. Unless you find a blockage to the pump there is no way to know which one is the cause of the "nd" code without some testing or replace these items.
If you are unafraid of facing your washer with tools in hand then you should be able to test the pump. As for the board, all you can do is check it for damage most likely caused from a component melt down. In which case it's going to need replacement.
But check for blockages first because that will cause the "nd" code.
I hope this helps and good luck.
Oct 06, 2009 | Maytag MAH6700AWW Neptune Front-Load...
My Maytag Neptune front load washer displayed ND with 19 left in wash cycle. Door won't open, what can I do?
Not draining,throw rugs tend to clog this unit as do bobby pins and under wires I'm giving you a link to the repair manual it covers the 3000 through 5500 it will help you get the door open and the clothes out so you can start bailing...
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Sep 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
ND - No Drain
Apr 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer wont rinse
we had the same problem with ours....nd means not draining and that means that there is something, probably coins stuck in your drain hose. pull the drain hose out and check it for change and make sure something isn't stuck.
Jul 21, 2008 | Maytag Neptune MAH9700 Front Load Washer
Maytag neptune washer code nd, what does it mean
May 03, 2008 | Maytag Neptune Washer
Maytag Neptune MAH9500A Front Load Washer Logo
221 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
