Pls. kindly tell me how do i reset error code 6400 on kyocera fs 1016 printer. also how to enter maintanance mode pls. tanks.
SOURCE: showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
SOURCE: Kyocera fs 1016 mpf printer
Code: 6400
Zero cross signal error
While fuser heater ON/OFF control is
performed, the zero-cross signal is not
input within 3 s.
Causes:
- Defective the power source PWB
- Defective the engine/high voltage PWB.
SOURCE: kyocera fs 1016 engine panic
Disassemble and look the fan side of the fuser, there you will see that the wires
pass through a **** that is more of a cover remove it and there's the
can on that side is where will the current regulator and the
high card that connects to the source card,
Well it
happened to me this issue, I found the card and it was high toner
developing unit that was discarding, in addition to the seal of the
doctor blade was worn out, another issue I found was current leakage,
what I did was make the can land top with more pressure to the high
card, in addition to not fall toner worn by the seal tape to tape the
holes in the chassis, after that I have not been flawed
SOURCE: KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
