Panasonic has the manual for the SD-YD250 here: http://service.us.panasonic.com/OPERMANPDF/SDYD250.PDF . This manual has several recipes at the end. Some recipes should not be done completely in the bread machine. (Follow the directions on using bread-machine flour or bread flour; the differences in the protein contents will matter.)
I hope this helps.
(the primary baker in my household prefers to knead her breads herself. The bread machine that was received as a gift got minimal use.)
SOURCE: misplaced manual for breadmaker
I found a pdf format version for you
http://support.panasonic.co.nz/docstore/SD200%20book.PDF
hope this helps :) have fun making bread!
SOURCE: Lost Manual Panasonic Breadmaker SD255
The other link is to the SD-YD250
The Panasonic SD-255 and SD-254 manual is: http://dlc.panasonic-europe-service.com/EUDocs/GetDoc.aspx?did=152761&fmt=PDF&lang=en&src=3&uilang=en-GB
SOURCE: Is the recipe manual the same for both the SD-BT65P & SD-YD250?
can't find a free one for you but here is a place you can purchase one for $9.95
Hope this helps
Pls rate the answer
Kurt
http://breadmakerguru.com/Panasonic/category.aspx?id=116
