Question about LG WM-2277HW Front Load Washer
LG Tromm washer constant DE door error problem
About a month ago my LG Tromm washer (approx 3 years old) began occasionally giving a DE door error and of course, stopping. I would open the door, close it, press the run button, and it would proceed. This has escalated to where it may give 20 or more DEs during each load. There is never anything I can see that is interfering with the door or its latch. Occasionally during one of these error marathons, it will display IE (input error)--again there is never anything at fault with the water input. Lately when the machine stops with a DE, it no longer unlocks the door, requiring me to press run, it immediately will go to DE again, and this second time, it will unlock the door.
  • 2 more comments
  • Anonymous Dec 07, 2008
    I have the same problem and now there is water in my machine that smells
  • Anonymous Apr 16, 2009
    I have the same problem with my 0642hw. I replaced the lock/switch assembly, but that didn't help. I also made sure that all seals are clean and that nothing is abstructing the door.
    As a side note, mine only does it during the rinse/spin cycle, but not during the actual wash cycle.
  • Anonymous Mar 12, 2014
    the door is closed, but an error message keeps coming up that says the door is open
  • Muhd Shafiq
    Muhd Shafiq Aug 13, 2018
    Success Tq!
  • 99 Answers
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
Posted on Dec 03, 2008
  • sharonziembi Nov 02, 2010
    My washer just gave me the same error.
    I cleaned the pump and emptied all the water from it.
    The pump is on the front of your washer under the door. Just remove the cover and unscrew. Have a pot to catch the water, it will stink.
    Then I checked the seal around the door and there was a dime in there and I removed it, now my washer is working again.
  • physicsngod
    physicsngod Jul 22, 2012
    there is a small hose that has to be clean also next to waste water filter behind the small door.
    Passionate:
    Visited the website for 10 consecutive days.
  • 164 Answers
Front load or topload? Ftontload needs door lock, top load and adjustment can be made.
Posted on Aug 13, 2018
    Sergeant:
  • 107 Answers
My washer used to have a door error problem as well. We called in an appliance repair specialist and got the problem fixed though. Something was in the way and jamming it up. I am so glad that we got the issue resolved. Appliance Repair for the St Petersburg FL Area
Posted on Aug 25, 2015
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
• Loose electrical connections at Door switch and
PWB Assembly.
• The DOOR SWITCH ASSEMBLY is out of order.
Posted on Jul 07, 2015
    New Friend:
Where to buy the magnet
Posted on Jul 01, 2015
    New Friend:
My top loading LG washing machine was showing dE error frequently. It seem a small magnet at the door latch had come off. So I took a permanent magnet from an electronic device and stuck to the machine with an adhesive tape from inside where the control panel is situated. The dE error has disappeared now! This is a temporary solution. I shall find a small piece of magnet soon to fit inside the door.
LG Tromm washer constant DE door error problem - lg-tromm-washer-constant-de-door-error-swnujdgcbe4dj0bhd4i5lkm4-5-0.jpg
Posted on Feb 03, 2015
  • Upendra Lele
    Upendra Lele Mar 03, 2015
    I later found a small round magnet which is used for sticking small reminder notes on refrgerator. It was a better solution.
6ya staff
SOURCE:
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
My LG TROMM washer is giving me an error code dE what does it mean?
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Apr 01, 2011 | Washing Machines
I have a LG DR 389 recorder:it refuses to read certain discs it has recorded-I have been using imation DVD-R and R. I noticed sometimes by removing the recorded disc immediately it is ejected the problem...
Region error code comes up when trying to play a disc.Has worked fine for 2 years, no setttings have been changed. Even new discs give thge same error
Aug 13, 2010 | Televison & Video
How much does a broken thermistor typically cost? My LG front loading washer is 3 years old...
THAT THING RARELY GO BAD. CHECK THE CONNECTIONS ON IT FIRST. UNPLUG AND PLUG CONNECTOR IN FEW TIMES. WHILE YOU DOWN THERE, PULL IT OUT COMPLETELY AND SEE IF IT COVERED WITH SOAP SCUM, GUNK, ETC. THAT WILL GIVE YOU FALSE READINGS AND GIVE YOU AN ERROR CODE FOR THE THERMISTOR
Aug 04, 2010 | LG WM2688HWM TROMM SteamWasher
I have exactly the same problem!
Try using the tub clean cycle and use a good dose of bleach or vinegear. Here is how to run the tub clean cycle.
To start the TUB CLEAN cycle:
1. Remove any clothing or items from the washer and close the door.
2. Open the dispenser drawer and add liquid chlorine bleach to the bleach compartment.
NOTE: Do not add any detergent to the detergent compartments. Excessive suds may be produced and leak
from the washer.
3. Close the dispenser drawer slowly.
4. Power On and then press the Extra Rinse button for 3 seconds. (Prewash option will be selected.)
5. Press the Start/Pause button to start.
6. After the cycle is complete, leave the door open to dry around the washer door opening, door seal and
door glass.
Jul 11, 2009 | LG WM2688HWM TROMM SteamWasher
My LG washer is 3 months old and it stinks!! This
check the sump its located under the drum be careful when removing, if not that its backflow from your sink waste where the washer waste is connected
Jun 24, 2009 | LG WM2688HWM TROMM SteamWasher
Drum does not spin
We have an LG TROMM with the same problem, 3 years old as well. We bought the extended warranty (Huge waste of $$$$).  So far they have determined it is not the motor or either of the control boards.  We think it might be a relay switch or possibly the brake.  Good luck with yours, we just went out and bought a new washer.
Jun 22, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM-2277HW Front Load Washer Logo
18,790 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
