Http://thesmartpartsestore.hobartservice.com/
Try espares uk its good
There are two different splash guards fort he A200.
If you have a 12 quart bowl the splash guard is a part number 438078 and if you have the 20 quart bowl the part number is 438079.
Both parts are available from
http://storefront.whaleyfoodservice.com/.
SOURCE: speed reduction of Hobart A200 mixer
Hi Don. If your mixer is hurling honey, you must be very popular in the ant world...Sorry!
The Hobart electric motor on your mixer was designed and engineered to operate on 115-120 volt current and is the most dependable, and capable commercial mixer out there Is it possible for you to use a commercial Imerssion Blender for the first part of your mixing operation. Once your honey thickens a bit perhaps the a200 wouldn't hurl honey. Another consideration would be to either try a different beater or modify the one you have by removing surface area from the beater. If you remove metal, be sure to do it in a balanced fashion to avoid unwanted vibration in the beater. If you're not up to removing metal, take it to a machine shop and they'll do it for you. It probably won't take long, or cost much, and they have the expertise and the equipment to do it properly. If you found this solution helpful, please rate it. Good luck! ricardok45.
SOURCE: on and off switch for hobart stand up mixer a200
I'm a hobart tech---what is the ml number on the data plate?
SOURCE: Hobart mixer A200 Rotation
I have a hobart a200 20qt mixer. the flat bitter is scraping the botttom of the bowl. The shaft looks little bend and i think it is and that is what's scraping the bowl at the bottom on one side only. the whole bowl is not being scraped. it used to work like that and now it does not work at all. the motore is running but the gears are not turing the mixer. Before the first geard stoped working but the other two were okay, now none of them work, but the motore is working.
