RCA F27242GY 27" TV Logo
Terry Fritsch Posted on Feb 04, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RCA f27242gy I bought my 18" Sony T.V. at an estate sale. I can't get it to change to any channels besides back and forth between 1 and 31?? Can anyone lend me some advise? I sure would like to watch some T.V.
Anonymous
Level 3:
President:
  • Master 1,284 Answers
  • Posted on Feb 04, 2007
Anonymous
Master
Level 3:
President:
Answers
1284
Questions
Helped
498670
Points
3271
If you have a remote control you should be able to access the "atuoprogram" feature within the setup menus. This will look for all active channels and place them into memory. What model is it?
How to get the right input for a conventional rca tv
Channel 3 is what you want anyways if you use the co-axial for the input. You can't have any other channels until you do a scan and there are no other channels anyways when you are using the tv as a monitor. So all your problems exist before that. Since the tuner is analogue and the satellite receiver is digital you may need a modern brown box.
Will a universal remote work on the RCA F27242GY 1999 TV?
If you must purchase a universal remote, please buy an RCA universal remote with menu and input buttons. You will be glad you did! Thanks for asking and show a few hands of support!
4helpful
1998 RCA TV Model F27242GY How do I connect a VCR/DVD player to this TV? Do I need to use a RF modulator or converter?
If this particular model does not have your typical RCA jacks in the front or back, Yes you will have to purchase an RF converter box. This is a common problem for the older conventional TV. Visit your local electronic store. Thanks for asking and show a few hands of support!
1helpful
TV TURNS ON AND OFF
My experience with the RCA F27242GY 27" TV going on and off is as follows:
Where the coaxial cable connects at rear and the base of the TV chassis part # 15062-57A is loose.
Informacion
por favor necesito codificar control remoto modelo rcr412si1612p para el televisor rca f27242gy
Turning rca tv to video
First did you try all the codes. Some codes do not activate that function to work with the TV. Second what type of TV is it . If it is a combination tv - vcr - dvd these are the hardest to get to work with a universal remote . good luck
24'' f27242gy
It looks like you will need to autoprogram the rest of the channels but do this you will need to have the TV connected to cable to store more than channel 3.
Good Luck.
RCA F27242GY
most likely it shorted out your hori output transistor,with this bad set will not come on.
Cannot tune to channel 0 to use my dvd
If television has rca outs in the back(yellow, red, and white connectors) you must use the remote on the television to change the video input mode. If you do not have the RCA's you need to go to Radio Shack or Wal Mart and by an RF Modulator. and follow the instuctions with the modulator.
ALL MY CHANNELS HAVE A BLACK PICTURE & FUZZY, PLEASE HELP
first off how good are you with a solder iron ? beside the obvious rf connector problem these set's had problems with bad solder connections within the tuner itself. google( sam goldwasser repair faq) for the solder template.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
