If you have a memory card inside the camera, you have to remove it and then turn on the camera, press the photo review button and you should see what is recorded in the internal memory? You can now delete the photos or recordings off the internal memory, mind you that most internal memory on cameras are limited but to a few photos only, you are better off using a regular SD card since it has way more memory than the internal memory in the camera.
The internal memory is very small and will only take a few pictures. Just enough to test the camera. Your camera also accepts SD and SDHC cards, which are not expensive. You can put lots of pictures on the SD or SDHC cards.
You also could connect the camera to a PC or MAC and send the pictures over after you installed Kodak Picture easy share.
After you backed up the pictures that way, you can delete the pictures in the camera. Always make sure you have at least 2 backups from your pictures.
Your Kodak camera has a limited amount of internal memory storage space which is the reason for the few pictures. What you need to purchase is an external memory card , an SD card with a maximum of 32GB, which you can insert within its battery bay. This card can hold hundreds and even thousands of pictures, depending on how many megapixels you set your camera on. For more information, go to this link: http://support.en.kodak.ca/app/answers/detail/a_id/19314/kw/c195/selected/true
Click review and then click delete it will ask if you want to delete all memory including internal click yes on "all photos and video" and this should clear it. Good Luck
