Specifically it is the gameloft oregon trail - american settler app. it goes through the loading screen, and just when it gets to the game screen it stops and goes back to the ipad home desktop. It just started doing this today, and I have been playing this app/game for over a week.
SOURCE: hi, since my last update i
The application probably needs an update. I recommend restarting the iPad and see if that helps at all. If not then as a last resort remove the app and reinstall it.
SOURCE: Please unblock me at UNO Gameloft they got me block for 4 days.
Use another computer to finish this game. Or apple should be helpful to fix this for you.
Android 4.0 Tablet PC
SOURCE: How to play 1080p mkv videos on the new iPad
Well, the new iPad only supports to playback videos in MP4, MOV, M4V format. So, if want to watch 1080p MKV videos on the new iPad in 1080p, you need to convert the 1080p MKV to 1080p MP4 format first. From Google search comes this following guide shows you how to convert 1080p MKV video to 1080p MP4 for the new iPad.
Read this "Turn 1080p MKV to 1080p MP4 for The New iPad"
SOURCE: I was just playing a game and the back of my iPad got really hot
You don't say which iPad, but if it is the newest one, it is said that it will will run up to 10 degrees warmer that the older ones. It should be nothing to worry about as long as you aren't using it is direct sunlight. One thing you can do that should help is to open up the multitasking bar (the app bar that shows all the apps open) and close some of them. It also should be covered by the warranty. If it get so hot that it can burn your skin, I would bring it back to store for replacement, but you should be ok. Don't be surprised if this is fixed by a future patch just like the iPhone 4s battery issue was fixed. Also, if it burns out and it obviously not your fault, it is covered under the warranty.
SOURCE: zynga poker iPad app doesn't open
Double tap the home button on your iPad and try closing the app from the row of apps that will appear at the bottom of the screen. Just press and hold the icon until the red x appears, then you will be able to close the app. Once you have closed it, try restarting the app.
If this does not solve the issue, then I would recommend removing the app from your iPad completely and reinstalling the Zynga Poker App.
