My MC4000 showed "Overload" on the screen. I cleaned and oiled it, and it still would not work. I took it to a repairman, and he said it needed a new motherboard. Do you know if it is possible to get a Motherboard for a Janome MC4000? Please let me know where to find one. Thanks
SOURCE: how to put on presser foot "p" to embroider
Not shure you can embroider on an MC4000, i think this is only a sewingmachine.
But to change presser fot:
If it a "snap on" foot, when foot lifted, press the "button" on the back of the needle bar (on the bottom) this would release the presser foot.
If is a large foot, you have to unscrew the screw on the left side of the needlebar, and change the whole foot.
SOURCE: janome 9000
The first thing to be checked is the fuse in the bottom of the machine. Have a different dealer do this check. If the screen lights up it is not a burned out fuse. Find an Authorized Janome dealer that you trust and let him check this machine.He is the only one who can get circuit boards from Janome. The machine does have built in diagnostics for some problems.
sewman7
SOURCE: used/new motherboard for MC 9000
This can be ordered from a Janome dealer only and he will have to order it from The Janome Company. They are not cheap so get the price first. It will be better if you can get him to install it for $70-80 dollars more because there may be some adjustments which need to be made when he finishes. It should also be cleaned and lubricated.That being said, I have a few questions for you.
When you plug the machine in and turn it on, does it light up at all? If the answer is no, then you need to check the lead cord.If the lead cord is okay,Then you need to check the fuse wich is located in a black box inside the bottom of the machine. Be sure you diagram the way the wires are before you disconnect them. Disassemble the black box and you will find 2 fuses in it. Usually only one is bad and it will be a 3.0 slow burn fuse. You will probably not find this at Radio Shack but you can find a 3.15 slow burn which works very well.. Be sure to reassemble everything the way it came apart. While you have the bottom of the machine off, blow it out wih air and lubricate every part that moves and rubs with a good quality sewing machine oil (not 3 in 1)
sewman7
SOURCE: janome 9000
Thank you Thank you .....i had taken this machine to a Janome dealer..he said it needed a new computer...i was scepticle wrote in here and guess what..it was a $2.00 fuse!!! see some ppl are just not HONEST!!! Thanks so much!!!
